"Motor Inventions" Airburner Accessory.
Topic author - Posts: 310
- Last Name: Hand
- * REQUIRED* Type and Year of Model Ts owned: 1912 open express, 1920 touring, 1926 tudor-lisenced and insured, 1921tt project 1922 fendered chassis, 192x tt dootle bug 192xengine w/winch projects
Wonder if anyone here on the Forum is using a Motor Inventions aluminum "Airburner" in place of the Ford Hot Air Pipe. I have one & it has a Thumb screw adjustment to the Proclaimed Efficiency, Has anyone that has one on their Ford modified this pipe & where do you set the Thumb Screw if you don't modify. George
Re: "Motor Inventions" Airburner Accessory.
What I am familiar with has a cast aluminum body with a round ball enlarged area @ the disk. The screw is to set the spring tension for the movement of the disk. It is actually designed to be an automatic choke. I think the ideal thing to do is to remove the auto choke feature disk.
