Paint remover
Topic author - Posts: 172
- Last Name: Burgett
Paint remover
Is there a good paint stripper that the EPA has not banned ? Aircraft remover used to be good. I am stripping a radiator shell.
John
John
- Last Name: Straw
- * REQUIRED* Type and Year of Model Ts owned: 1915 and lots of parts
Re: Paint remover
Easy-Off oven cleaner
- Last Name: Strange
Re: Paint remover
3M used to (and may still) sell a product called "Safest Stripper". I have used it in the past with good results and can confirm it is not nearly as caustic as classic stripper.
Re: Paint remover
All depends on the kind of paint. Aircraft Remover is about the only thing for Powder Coat. Lacquer thinner works on some. Most of the new stuff is citrus based and works well. Start with what yo u have and if that doesn't work - follow recomendationsJohn Illinois wrote: ↑Wed Sep 01, 2021 5:20 pmIs there a good paint stripper that the EPA has not banned ? Aircraft remover used to be good. I am stripping a radiator shell.
John
- First Name: Ignacio
- Last Name: Valdes
Re: Paint remover
Citri-strip and a wire wheel on a drill or grinder works well. It usually takes 2 or 3 treatments though to get all the last little bits off.
Re: Paint remover
Thanks for the suggestions. I will see what is available.
John
John
- First Name: Don
- Last Name: Keil
- * REQUIRED* Type and Year of Model Ts owned: 26 roadster
Re: Paint remover
water lye corn starch .I am not pc
