Up to the bit of the restoration where we put the Spare tyre carrier in place, before I pull it all to bits to start the paint.
Do the kinks in the arms look right? The left has a much more pronounced kink than the right.
Got a fair bit of straightening up of the lighter flat steel.
The angle brace across the top measures 17 1/2 inches, which I gather is correct for 21 inch rims.
Opinions on the distortions ( if that's what they are) in the arms would be appreciated.
'25 Coup Spare Tyre Carrier
Topic author - Posts: 44
- First Name: Tony
- Last Name: Howard
- * REQUIRED* Type and Year of Model Ts owned: 1926 Tourer 1925 Coup
Government - because people struggle to ruin their lives by themselves
- Last Name: van Ekeren
Re: '25 Coup Spare Tyre Carrier
An easy one to answer, the kinks shouldn't be there at all. To give you an idea on the angle when things are all straight. Top of the spare is about 9" from the boot lid edge.
- First Name: Tony
- Last Name: Howard
OK . Thanks for the quick reply. Appreciate much the photos. Out with the Oxy Acetylene torch and the anvil in the morning.
Tony, I spotted that Dunlop tyre tread and had to check where the post came from.They were last made in the 1960''s. I put a new old stock set on my 1912 Haigh's chocolate van in 1994 and they are still going strong. They'll probably see me out. If only we could buy such quality today.
Allan from down under, too.
- First Name: Tony
- Last Name: Howard
It's ironic isn't it , that the good stuff we used to manufacture in Oz no longer exists and we somehow have come to accept that second rate throwaway is the norm.
