Connecting rods
Topic author - Posts: 3
- First Name: Lee
- Last Name: Taylor
- * REQUIRED* Type and Year of Model Ts owned: 1915 run about. 1926 roadster
- Board Member Since: 2014
Connecting rods
I have to cut and weld model A and model T rods together. Where is the best place to do it Near the big end or small end or in the middle.
Re: Connecting rods
I'm not sure it would matter. What are you building?
- First Name: Lee
- Last Name: Taylor
Re: Connecting rods
A friend bought 2 bumac cranks from snyders but when they arrived the journals were model a size. I have line bored the block and rebabitted and burned to suit. You used to be able to get egge pistons to suit but not now I believe. Therefore I need to cut the model a rods and weld on part of a t rod to get the right t Gurgaon end and thr right length. I think Les Schubert has done this before but I don't know how to get in touch with him.
- First Name: harold
- Last Name: musolf
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 1926 touring 1913 touring
- Board Member Since: 2010
Re: Connecting rods
I believe that Scat makes a rod that is model A on the big end and model T on the small end. I will look thru my notes to verify.
Harold
Harold
- First Name: Lee
- Last Name: Taylor
Re: Connecting rods
Thank you for your reply. I look forward to see what you find.
Re: Connecting rods
you might get more help posting on the general forum, this section is for questions about the site, not cars.
