Is This A Common Color From A Non Model T?
Topic author - Posts: 712
- First Name: Michael
- Last Name: Pawelek
Re: Is This A Common Color From A Non Model T?
Machinery gray's were quite common over the years but varied. I would look at a good color chart from an equipment enamel company like Rust oleum or similar and choose one you like. Better yet would be a high temperature engine enamel. It may change somewhat with age.
The true color has probably changed with time and heat. To me it looks a little blue from what probably was a true grey.
Probably best way to match would be a color chart for a high temp enamel as Rich has said. Might not get it perfect but pretty close and remember the new one will change over time.
- Last Name: House
Only need high temp (1500*) for the exhaust manifold. Go to TSC and buy Ford gray for the engine.
- Last Name: Clements
It kind of looks like faded out Ford Tractor Grey.
- First Name: Duane
- Last Name: Cooley
Battleship gray was the color of the day. A light gray as in your pic. I used Northwest Airlines gray on an OT. Darned close.
Machinery gray is darker, yet prevalent as a replacement for Battleship gray in the 80's. They didn't know.
Both can turn blue in UV.
Also try City of Montreal gray. A Battleship gray.
I like that gray. I'm a centric OT guy tho.
The '18 T engine here was originally green.
Just a view from somewhere outside the box.
- First Name: craig
- Last Name: leach
Hi Micheal.
Oriellys has Plasticoat engine paint in Ford grey, it's a little darker when not faded out. Holds up well. They also have a Castblast engine paint that looks good for parts that where not painted. I have had good luck with that product line but prep is the key to a long lasting paint job.
Craig.
Craig.
- First Name: Bob
- Last Name: Middleton
Machinery grey what my grand dad called it or battleship grey
