Is This A Common Color From A Non Model T?
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Wed Sep 08, 2021 5:59 pm
Does this grey color have a common name used in other years besides the Model T? Would like to buy off the shelf rather than try to have it matched.
Re: Is This A Common Color From A Non Model T?
Post by Rich Eagle » Wed Sep 08, 2021 6:21 pm
Machinery gray's were quite common over the years but varied. I would look at a good color chart from an equipment enamel company like Rust oleum or similar and choose one you like. Better yet would be a high temperature engine enamel. It may change somewhat with age.
Post by John kuehn » Wed Sep 08, 2021 6:39 pm
The true color has probably changed with time and heat. To me it looks a little blue from what probably was a true grey.
Probably best way to match would be a color chart for a high temp enamel as Rich has said. Might not get it perfect but pretty close and remember the new one will change over time.
Last Name: House
Post by George House » Wed Sep 08, 2021 6:57 pm
Only need high temp (1500*) for the exhaust manifold. Go to TSC and buy Ford gray for the engine.
Scott C.
Last Name: Clements
Post by Scott C. » Thu Sep 09, 2021 1:49 am
It kind of looks like faded out Ford Tractor Grey.
Duey_C
First Name: Duane
Last Name: Cooley
Post by Duey_C » Thu Sep 09, 2021 3:12 am
Battleship gray was the color of the day. A light gray as in your pic. I used Northwest Airlines gray on an OT. Darned close.
Machinery gray is darker, yet prevalent as a replacement for Battleship gray in the 80's. They didn't know.
Both can turn blue in UV.
Also try City of Montreal gray. A Battleship gray.
I like that gray. I'm a centric OT guy tho.
The '18 T engine here was originally green.
Just a view from somewhere outside the box. :)
First Name: craig
Last Name: leach
Post by Craig Leach » Thu Sep 09, 2021 10:06 pm
Hi Micheal.
Oriellys has Plasticoat engine paint in Ford grey, it's a little darker when not faded out. Holds up well. They also have a Castblast engine paint that looks good for parts that where not painted. I have had good luck with that product line but prep is the key to a long lasting paint job.
Nv Bob
First Name: Bob
Last Name: Middleton
Post by Nv Bob » Thu Sep 09, 2021 11:12 pm
Machinery grey what my grand dad called it or battleship grey
