ID this mystery tube
Topic author - Posts: 293
- First Name: Jason
- Last Name: Bogstie
I have this tube coming out of my 1920 engine. Can you all tell me what it's for?
- Last Name: Strange
- Board Member Since: 2013
Re: ID this mystery tube
Maybe it was a return for an external oiling system that somebody blocked off with a hose and clamped nut?
- Last Name: Wrenn
Whatever it is I'd get rid of it and plug the outlet opening tightly! That looks like a disaster waiting to happen.
- First Name: Michael
- Last Name: Pawelek
Someone in the past may have been trying to keep the front dip full of oil for driving up very steep hills. I would cap it off right at the pan.
Why take if off, just add a Sure-Feed type oiler to the transmission cover and use it.
- First Name: Jason
I'm not familiar with those. Where can I find them?Mark Gregush wrote: ↑Sun Sep 12, 2021 9:58 pmWhy take if off, just add a Sure-Feed type oiler to the transmission cover and use it.
- First Name: Kevin
- Last Name: Matthiesen
From the pictures it looks like it is on the right side of the motor. You will need to use a Ford Faithful type oiler that replaces the stock transmission inspection cover, Chafins is making a repo I think. The Sure Feed oiler comes off the left side of motor and wouldn't work.
- First Name: Kevin
From the pictures it looks like it is on the right side of the motor, yes right side.
http://www.mtfca.com/discus/messages/17 ... 1311799547
http://www.mtfca.com/discus/messages/41 ... 1401574008
There were a couple of different brands, but work about the same. When I install mine, I will be feeding in from the location you have that fitting.
Another possibility to where it might go - but unlikely. What do you know about your engine?
- Attachments
- oiler 2.png (616.51 KiB) Viewed 2034 times
