ID this mystery tube
JBog
First Name: Jason
Last Name: Bogstie
Post by JBog » Sun Sep 12, 2021 3:07 pm
I have this tube coming out of my 1920 engine. Can you all tell me what it's for?
Last Name: Strange
Re: ID this mystery tube
Post by CudaMan » Sun Sep 12, 2021 3:31 pm
Maybe it was a return for an external oiling system that somebody blocked off with a hose and clamped nut?
Last Name: Wrenn
Post by TWrenn » Sun Sep 12, 2021 3:52 pm
Whatever it is I'd get rid of it and plug the outlet opening tightly! That looks like a disaster waiting to happen.
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Sun Sep 12, 2021 4:58 pm
Someone in the past may have been trying to keep the front dip full of oil for driving up very steep hills. I would cap it off right at the pan.
Post by Mark Gregush » Sun Sep 12, 2021 9:58 pm
Why take if off, just add a Sure-Feed type oiler to the transmission cover and use it.
JBog
First Name: Jason
Last Name: Bogstie
Post by JBog » Sun Sep 12, 2021 11:46 pm
I'm not familiar with those. Where can I find them?
kmatt2
First Name: Kevin
Last Name: Matthiesen
Post by kmatt2 » Mon Sep 13, 2021 1:41 am
From the pictures it looks like it is on the right side of the motor. You will need to use a Ford Faithful type oiler that replaces the stock transmission inspection cover, Chafins is making a repo I think. The Sure Feed oiler comes off the left side of motor and wouldn't work.
kmatt2
First Name: Kevin
From the pictures it looks like it is on the right side of the motor, yes right side.
JBog
First Name: Jason
Last Name: Bogstie
Post by JBog » Mon Sep 13, 2021 10:29 am
Yea, it's on the passenger side of the tourer.
Post by Mark Gregush » Mon Sep 13, 2021 11:46 am
http://www.mtfca.com/discus/messages/17 ... 1311799547
http://www.mtfca.com/discus/messages/41 ... 1401574008
There were a couple of different brands, but work about the same. When I install mine, I will be feeding in from the location you have that fitting.
Post by TRDxB2 » Tue Sep 14, 2021 11:21 am
Another possibility to where it might go - but unlikely. What do you know about your engine?
oiler 2.png (616.51 KiB) Viewed 2163 times
