1915ish Coil box switch wiring? Lights?
ivaldes1
First Name: Ignacio
Last Name: Valdes
Post by ivaldes1 » Mon Sep 13, 2021 3:38 am
Hello all, I have just started wiring this coil box. The top row of contacts is for the commutator, the second row is to the spark plugs. I assume that the third row of 2 contacts is for switching and maybe lighting? I don't know what they are for. How one might wire and the driver turns on and off lights on a speedster mix such as this? Guidance is much appreciated.
John iaccino
Last Name: Iaccino
* REQUIRED* Type and Year of Model Ts owned: 1911 Roadster, Open Runnabout
Re: 1915ish Coil box switch wiring? Lights?
Post by John iaccino » Mon Sep 13, 2021 6:43 am
The bottom two are for battery and magneto connections.
Post by Allan » Mon Sep 13, 2021 7:04 am
Lights are wired on a separate switch, to the side of the coilbox on a 1915 model.
George Mills
Last Name: Mills
Post by George Mills » Mon Sep 13, 2021 11:32 am
Ignacio,
How 1915ish are you going to be? With a Speedster lots of liberties can be made. For an absolute true 1915 approach, complete with magneto driven headlights, the following schematic applies....
(I'd verify the dash switch as to which side is which with a continuity tester before doing anything. Some folks get the switch 'backwards').
Since it's a speedster, you might want to consider chucking the magneto headlight power and going with DC? Thats a different wiring diagram as you'd have to come up with a 2-position switch...and wire the headlight buckets in parallel and NOT in series as shown in the schematic.
WayneJ
Last Name: Jorgensen
Post by WayneJ » Mon Sep 13, 2021 12:14 pm
Wayne s Model T Speedometer s.jpg (45.8 KiB) Viewed 1651 times
The headlight switch on my 1915 is to the right of the coil box, left of the the speedometer, and below the carburetor adjustment knob as shown in the above photo.
Wayne Jorgensen, Batavia, IL
1918 Runabout
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Mon Sep 13, 2021 12:42 pm
Here a couple links to color wiring diagrams.
MTFCI Wiring Links
Schematics
https://nebula.wsimg.com/3e10aca08d1115 ... oworigin=1
Harness Diagrams
https://nebula.wsimg.com/3a0733937917a1 ... oworigin=1
Respectfully Submitted,
Be_Zero_Be
Hudson29
First Name: Paul
Last Name: O'Neil
Post by Hudson29 » Mon Sep 13, 2021 2:38 pm
Thanks for the wiring links. I'm not an electrical sort but these may be helpful in figuring out the hodgepodge of wires on my non stock electrified '14.
Paul
