Refinishing Bridgeport Brass Tire Pump
WayneJ
Last Name: Jorgensen
Post by WayneJ » Sat Sep 18, 2021 4:51 pm
I am in the process of refinishing a two cylinder, Bridgeport Brass tire pump for my 1915 Model T. What finish should be on the top cast iron part that is on top of the two brass cylinders?
This is the part I am referring to.
Wayne Jorgensen, Batavia, IL
1918 Runabout
Re: Refinishing Bridgeport Brass Tire Pump
Post by DanTreace » Sat Sep 18, 2021 5:32 pm
This Youtube video on restoration of an original shows the orange red color on the top fitting, same as the foot color.
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
* REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo,1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet, 1917 Coupelet
Post by Russ_Furstnow » Sat Sep 18, 2021 8:18 pm
The top of the pump casting is brass plated. The bottom casting is painted red. The hose is red rubber. I hope this heps. Russ Furstnow
WayneJ
Post by WayneJ » Sun Sep 19, 2021 12:02 am
I had seen the You Tube video before I posted, but I questioned the red color of the top casting of the restored You Tube video pump, as I see no trace of red paint on the top casting of my pump. Russ Furstnow confirms my suspicion that the top casting was not originally painted red, as in the You Tube video. Thanks to all who responded.
1918 Runabout
Post by DanTreace » Sun Sep 19, 2021 4:15 pm
Russ
Thanks for that clarification,missed that and should have remembered seeing those dual cylinder pumps with show car displays.
Here is a nice one.
100_4812 (800x533).jpg (94.93 KiB) Viewed 1585 times
As noted, the pump hose should be red rubber......
