MOUNTING HEADLIGHTS ?
Topic author - Posts: 760
- Last Name: S
I'm trying to come up with a way i can use pre '26 headlights on a '26 frame.
Anybody have some pics?
***planning on using pre '26 headlights and mounts.
________________
**FATE**
**FATE**
- Last Name: Hanlon
Re: MOUNTING HEADLIGHTS ?
Earlier headlights mount to the fender irons.
If you have 26 fenders, you’ll have to cut a hole in them.
- Last Name: S
My '26 will be clean with no fenders. That's why I need the earlier brackets that mount to the frame.
I have to clear a lot of extra metal up front at the bottom of the radiator in order to get a clean install.
I'm hoping somebody brainstormed a good way around '26 frame obstacles.
________________
**FATE**
**FATE**
Could you shorten/bend a pair of junk Model T or A rods to make brackets?
- Last Name: S
Brackets aren't the issue.
It's the attachment of bracket to frame that interests me.
I'm using pre'26 headlights and brackets
________________
**FATE**
**FATE**
- First Name: Brent
- Last Name: Burger
- Board Member Since: 2014
Two words, .... Fabricate ! Fabricate ! Fabricate !
- Last Name: S
that's why I asked for pictures!Burger in Spokane wrote: ↑Mon Sep 27, 2021 1:35 amTwo words, .... Fabricate ! Fabricate ! Fabricate !
Last edited by Professor Fate on Mon Sep 27, 2021 7:54 am, edited 1 time in total.
________________
**FATE**
**FATE**
- Last Name: S
I managed to "fabricate" from a 5 sheet plans set to build my csssutt. And I collected pictures then as i am now to get ideas to "fabricate"
________________
**FATE**
**FATE**
Go to the "Hay Wagon to Speedster Project' thread, about 10 threads down.
Scroll down to Thursday Dec 10, 2020 1:39am post.
There you will see photos of amputated frame horn for the '26-'27 fender mount. Then drill holes to mount the earlier fender/headlamp bracket. Cut of the fender iron to suit, just above the lamp mounting hole.
Photo of cut off pre-'26 fender bracket to mount just the headlamps.
