Question About Radiator Cap
BLB27
First Name: Bruce
Last Name: Brakke
Post by BLB27 » Tue Oct 05, 2021 7:59 pm
Should there be a rubber gasket under the radiator cap?
Last Name: Humble
Board Member Since: 2006
Re: Question About Radiator Cap
Post by Humblej » Tue Oct 05, 2021 8:02 pm
A Ford stock radiator cap?
Post by DanTreace » Tue Oct 05, 2021 10:16 pm
Yes
Ford part #3927
Post by RajoRacer » Tue Oct 05, 2021 10:29 pm
It was a paper gasket, I believe - not rubber. If you have a motometer or a decorative cap, one could use a rubber gasket or an o-ring to assist in the proper alignment.
Professor Fate
Last Name: S
* REQUIRED* Type and Year of Model Ts owned: '23 and '26
Post by Professor Fate » Tue Oct 05, 2021 10:40 pm
Lang's has the rubber gasket you need. [Order an extra for later.]
________________
**FATE**
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Tue Oct 05, 2021 11:07 pm
Or stop at your local hardware store, even the big box store, and get a drain gasket.
Post by Allan » Tue Oct 05, 2021 11:18 pm
The problem is the thin edge on the original radiator cap. When you screw the cap down, that thin edge engages right on the outside of any gasket used, and often the gasket is distorted and the cap doesn't seal anyway. If you can find one of the caps with the rolled in edge below the thread, you are on a winner.
I make my own, cut off the end of a red urethane boat trailer roller. They end up about 1/8" thick, have a smaller hole in the middle and thus do not so easily distort. My little finger pulls it out if ever I need to top up the radiator.
First Name: craig
Last Name: leach
Post by Craig Leach » Wed Oct 06, 2021 1:28 am
Yes gasket, of some kind. unless you like cleaning the hood & windshield. Or goggles if you have Speedster.
Craig
Alan Long
First Name: Alan
Last Name: Long
Post by Alan Long » Wed Oct 06, 2021 4:59 am
Paper gaskets are rubbish. I use (and love) Part # 3927M from Lang’s.
It’s nice n thick, rounded end that fits nicely into the Radiator Neck, made of Neoprene and cost $1.65. Bargain.
As suggested by others it has a bit of compression to align the Cap or fancy wings or temperature gauges!
Easily flicked out when coolant topping up is needed. Get a couple
Alan in Western Australia
Post by TRDxB2 » Wed Oct 06, 2021 9:59 am
Old thread suggest using a popup drain gasket as it is the same as sold by vendors and available in most hardware & ome Improvement stores
http://www.mtfca.com/discus/messages/59 ... 1460135057
Professor Fate
Last Name: S
Post by Professor Fate » Wed Oct 06, 2021 8:24 pm
I run my Lang's neoprene [sorry I called it rubber] gasket smooth side down. I have gotten 3-4 yrs out of a new one before replacement.
________________
**FATE**
