You may be addicted to Model T fords when…..
Thorlick
Topic author - Posts: 214
- First Name: Terry
- Last Name: Horlick
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster Pickup "Mountain Patrol vehicle" from Los Angeles City Fire Department and a 1912 Model T omnibus restoration project
all you notice is the wrong rear windows!
- Last Name: Hatch
Re: You may be addicted to Model T fords when…..
Maybe not. Isn’t that a Canadian car?
JohnM
- Last Name: Michaelree
- Board Member Since: 2010
When you can watch and sit through all of Scott C's socially distancing videos.
Don D
- First Name: Don
- Last Name: Demio
- * REQUIRED* Type and Year of Model Ts owned: 1919 T
you are near a bee hive and look around for a running "T"
Windshield indicates that it is a Canadian car. Lower pane is hinged. Canadian slanted could be as early as 1920. Canadian slanted windshield that early could also have a one man top, and two oval rear lites were used on many Canadian tops.
What I want to know is why are the sidelamps mounted at different heights? One is slightly above the cowl bead, the other is slightly below the cowl bead.
Wayne, you are suffering from an optical delusion!
If you put a straight edge beween the tops of the two lamps you will have a line perfectly parallel to the bottom of the windscreen.
- Last Name: Tannehill
What really gives it away is the drivers side front door is hinged!
TonyB
- First Name: Tony
- Last Name: Bowker
Ooops I put this in the wrong thread.
Sorry. TonyB
Sorry. TonyB
Tony Bowker
La Mesa, California
La Mesa, California
david_dewey
- First Name: David
- Last Name: Dewey
Hmm, what I notice is the glass-cased electric meter on the building behind the car, and the modern sidewalk joints. There's probably more stuff, but that's what jumps out at me.
T'ake care,
David Dewey
David Dewey
marctee
- First Name: Marc
- Last Name: hall
- * REQUIRED* Type and Year of Model Ts owned: 1924
That T makes the neighborhood looks even nicer !
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
...when the T gets a parking spot in the garage and the wifes new car is parked outside.
Quickm007
- First Name: Mario
- Last Name: Brossard
That's the actual case of my wife...
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
Will Brown
- First Name: Will
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 26 Runabout
The aluminum gutter is another discrepancy. It is obviously meant to be a Candian T as it has an Ontario license plate.
I wonder if the driver is aiming at the man walking behind him or someone else?
tmodeldriver
- First Name: Robert
- Last Name: Hester
- * REQUIRED* Type and Year of Model Ts owned: 26 touring, 27 touring, 22 TT
Only in the USA do we park cars worth tens of thousands of dollars out in the weather and fill our garages up with worthless junk.
