You may be addicted to Model T fords when…..
Thorlick
First Name: Terry
Last Name: Horlick
* REQUIRED* Type and Year of Model Ts owned: 1927 Roadster Pickup "Mountain Patrol vehicle" from Los Angeles City Fire Department and a 1912 Model T omnibus restoration project
Post by Thorlick » Thu Oct 14, 2021 10:56 am
all you notice is the wrong rear windows!
Wrong rear windows
Wrong rear windows
Last Name: Hatch
Re: You may be addicted to Model T fords when…..
Post by Dan Hatch » Thu Oct 14, 2021 2:07 pm
Maybe not. Isn’t that a Canadian car?
JohnM
Last Name: Michaelree
Board Member Since: 2010
Post by JohnM » Thu Oct 14, 2021 2:39 pm
When you can watch and sit through all of Scott C's socially distancing videos. :D
Don D
First Name: Don
Last Name: Demio
* REQUIRED* Type and Year of Model Ts owned: 1919 T
Post by Don D » Thu Oct 14, 2021 3:01 pm
you are near a bee hive and look around for a running "T" :-)
Post by Wayne Sheldon » Thu Oct 14, 2021 8:34 pm
Windshield indicates that it is a Canadian car. Lower pane is hinged. Canadian slanted could be as early as 1920. Canadian slanted windshield that early could also have a one man top, and two oval rear lites were used on many Canadian tops.
What I want to know is why are the sidelamps mounted at different heights? One is slightly above the cowl bead, the other is slightly below the cowl bead.
Post by Allan » Thu Oct 14, 2021 8:49 pm
Wayne, you are suffering from an optical delusion! :D If you put a straight edge beween the tops of the two lamps you will have a line perfectly parallel to the bottom of the windscreen.
Last Name: Tannehill
Post by JTT3 » Thu Oct 14, 2021 9:44 pm
What really gives it away is the drivers side front door is hinged!
TonyB
First Name: Tony
Last Name: Bowker
Post by TonyB » Thu Oct 14, 2021 9:53 pm
Ooops I put this in the wrong thread.
Sorry. TonyB
Tony Bowker
La Mesa, California
david_dewey
First Name: David
Last Name: Dewey
Post by david_dewey » Fri Oct 15, 2021 2:02 am
Hmm, what I notice is the glass-cased electric meter on the building behind the car, and the modern sidewalk joints. There's probably more stuff, but that's what jumps out at me.
T'ake care,
David Dewey
marctee
First Name: Marc
Last Name: hall
* REQUIRED* Type and Year of Model Ts owned: 1924
Post by marctee » Fri Oct 15, 2021 3:52 am
That T makes the neighborhood looks even nicer !
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Fri Oct 15, 2021 7:16 am
...when the T gets a parking spot in the garage and the wifes new car is parked outside.
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Sat Oct 16, 2021 2:19 pm
That's the actual case of my wife... :lol:
Super Mario Bross ;)
1911 Touring
1914 Speedster
Will Brown
First Name: Will
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 26 Runabout
Post by Will Brown » Sat Oct 16, 2021 3:52 pm
The aluminum gutter is another discrepancy. It is obviously meant to be a Candian T as it has an Ontario license plate.
Post by Norman Kling » Sat Oct 16, 2021 4:13 pm
I wonder if the driver is aiming at the man walking behind him or someone else?
Post by Norman Kling » Sat Oct 16, 2021 4:14 pm
tmodeldriver
Last Name: Hester
* REQUIRED* Type and Year of Model Ts owned: 26 touring, 27 touring, 22 TT
Post by tmodeldriver » Mon Oct 18, 2021 3:07 pm
Only in the USA do we park cars worth tens of thousands of dollars out in the weather and fill our garages up with worthless junk. :roll:
