Is this Threshold Correct?
SurveyKing
Topic author - Posts: 504
- First Name: Daniel
- Last Name: Snell
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
- Board Member Since: 2014
Can someone post a photo of a correct threshold for a 23-25 Rear Touring Door? This photo is of my right rear threshold for my 1924, should the metal pieces be joined here or is this correct?
Re: Is this Threshold Correct?
Correct, except typical production the wood filler pieces above the sill are tapered up and a bit more flush with the edges of the metal threshold at each upper corner. The exposed wood painted with body pieces installed.
View at rear seat heel panel
View at front seat backrest toe panel
Another view rear seat toe panel
SurveyKing
- Last Name: Snell
Thanks Dan for posting those pics, a big help. Would you know what kind of wood those filler pieces are?
HornsRus
- First Name: Charley
- Last Name: Shaver
- * REQUIRED* Type and Year of Model Ts owned: 1913
buy 23 wood was hard to get so most was pine. or any scrape on the floor.ha,ha. that's why they went to steel bodies. charley
SurveyKing
- Last Name: Snell
Hi Charley, did you get my list of bolts, nuts that I need? Daniel Snell
SurveyKing
- Last Name: Snell
Dan Trace, On this photo I have circled a lip that is on the narrow threshold below the door. Is this lip supposed to go into a slot on the wood rail below? Mine is just resting on the wood rail and there is a space below it.
Daniel. Isn’t a slot in the wood sill, that stamped metal threshold piece just folds over. Variations in assembly of parts will occur with our Model T’s!
HornsRus
- Last Name: Shaver
yes i have your list! i will be working on it. charley
