If you need help logging in, or have question about how something works, use the Support forum located here
Support Forum
Oldrusty26
- First Name: Travis
- Last Name: Melnick
- * REQUIRED* Type and Year of Model Ts owned: 26 Rpu 27 Tudor 25 TT etc...
- Board Member Since: 2012
Post
by Oldrusty26 » Sun Oct 17, 2021 9:51 pm
- 05E9B951-7BFA-46D2-A362-B804E12C56B5.jpeg (14.82 KiB) Viewed 1170 times
- 575975E4-F31C-49F5-A301-4376828114EA.jpeg (16.6 KiB) Viewed 1170 times
- 81B8E965-1487-4146-BA4A-75C3F55939C3.jpeg (16.93 KiB) Viewed 1170 times
Found these today during an outing on an old farm , hoping to get some information on them , intake manifolds , same spacing as the T , but like a lot of things , I’ve never seen them before , aftermarket ? Not ford ? Ideas ??
Thanks in advance .
Post
by Scott_Conger » Sun Oct 17, 2021 10:27 pm
Aftermarket...used for any number of updraft carbs where interference with a generator is not an issue. The bottom one is commonly found with Meyer updraft carbs.
If you ever sell them, I'd be interested.
