In a recent publication, a technical writer says he recommends sodium grease for front and rear wheel bearings on a model A due to its fiberous properties. Reading an MSDS sheet, it indicates sodium grease works well on slower turning bearings where high heat is not indicated. However, sodium greases do not like water. Some Articles indicate water turns sodium grease into a soapy solution. I’ve always used lithium compound or heat temp greases for most applications. Does anyone have an opinion on sodium grease? Due to its stringy texture, I wonder how it would work on a u joint? No heat, very sticky and I wonder how it would help holding oil from coming through a u joint?
Sodium bearing grease
Topic author - Posts: 429
- First Name: Tom
- Last Name: Moorehead
Re: Sodium bearing grease
That sounds like Texaco Marfak grease. It was widely used in decades past. I don't know if it is still available.
I would avoid it due to its inability to survive immersion
any waterproof NLGI 2 grease is fine
- First Name: Tom
It is still available cause I bought some before I realized the issue with water. I’m still going to try it in the fourth main.
- First Name: Tom
Rather the u joint!
