Today I finished the re-assembly of my Lizzy.
Checking the spark firing sequence (1-2-4-3), I hand cranked slowly and watched which coil is active. Sequence is ok, but I see a relatively strong firing.
Is it possible to add a capacitor on the trembler coils directly? I mean in a way that I do not have to dig into the coil to replace the internal capacitor?
Reduce contact-fire on Trembler Coil buzzer
Topic author - Posts: 256
- First Name: Rainer
- Last Name: Hantsch
- * REQUIRED* Type and Year of Model Ts owned: Model T Touring 1916, brass & black
Model T Touring 1916 (brass & black), 95% original
I am from: AUSTRIA, EUROPE
Re: Reduce contact-fire on Trembler Coil buzzer
Yes. seen it done. Make sure it clears the coil box lid. My feeble memory says it can be placed out on a terminal post. Dont quote me on this. Might be worth confirm/deny. In fact, A coil wizard will be visiting . Ill ask directly.
I am not advocating doing this but it has been done by others as a temporary fix.
http://www.mtfca.com/discus/messages/50 ... 1424318130
Doing it the right way may be easier in the long run when trying to protect an external connected capacitor to the coil posts from shorting when securing the lid. The lid is needed to keep the coils form moving and loosing their contacts. Its also important to use the capacitor matched to the coil so maybe there lies the problem. http://www.mtfca.com/discus/messages/80 ... 1248132830 --
Some videos to replace the internal capacitor
https://www.youtube.com/watch?v=FyqwOVLbuek
https://www.youtube.com/watch?v=B1zT53oBFck
- 3 part expert instructions
https://www.youtube.com/watch?v=uhaxW3jaG0Q
https://www.youtube.com/watch?v=br78FzWKlV8
https://www.youtube.com/watch?v=nZH0QNwB0rM
Thank you so much.
I will try without hood if contact fire will strongly reduce with externally attached capacitor.
If it works, I think about opening my ignition coils, otherwise I let it be. Therefore I am asking for the external cap before having unnecessary work.
At Chaffin's we use a 0.47 uf, 400V polypropylene capacitor with a dV/dt rating of 6000.
- Last Name: Hunter
- Board Member Since: 2002
Definitely a temporary fix, and only for an open circuit internal capacitor. If the internal capacitor is excessively leaky, then no amount of external capacitance will fix the problem. Also, if the internal capacitor is open circuit with an intermittent connection, if the connection comes good then the amount of capacitance is increased - not that it will stop the coil functioning.
I did speak with my coil genus. Must be connected between upper & lower points. If you want to drill a hole or holes, you can in theory have 4 remotely mounted any where.speedytinc wrote: ↑Sun Oct 31, 2021 10:07 amYes. seen it done. Make sure it clears the coil box lid. My feeble memory says it can be placed out on a terminal post. Dont quote me on this. Might be worth confirm/deny. In fact, A coil wizard will be visiting . Ill ask directly.
