Adjusting toe in
Topic author - Posts: 147
- Last Name: Leffler
- * REQUIRED* Type and Year of Model Ts owned: 1923 Coupe, 1927 Touring
Adjusting toe in
Ok ; got my axle straight and ready to put it back together. What is the best way to adjust toe in ,toe out?
Re: Adjusting toe in
Sending you an email.
- First Name: CHARLIE
- Last Name: BRANCA
- Board Member Since: 2010
You really want to get it right? Sure you do and the best garage way I’ve found is to get 4 pieces of tin or galvanized about 4” square. Make 2 sandwiches of grease between 2 pieces and put one under each front tire so they slide easy. Nothing beats the accuracy you’ll get if those tires can move.
- First Name: Anthonie
- Last Name: Boer
I do it a little differed
Toon
Toon
- Last Name: Osterman
Like the system … but white carpet in a garage housing a model T. Boy are you brave.
- Last Name: Gould
Clever, Anthonie!
- First Name: Mario
- Last Name: Brossard
Toon, I like your way. What measurement we need to have?
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- First Name: Edward
- Last Name: Baudoux
I like to use magazines or catalogs for slip pads. Most model T Ford front ends are loose enough to use 1/4" of toe in.
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
I mark the tires front & roll back 1/2 revolution.
Pretty much how I do it and explained to him, but I use a clamped pair of yardsticks to guage the distance front and back, and have had excellent results. Much easier. Helps to have a lift also!
On my '13 I have zero toe in..really rolls nice. Other two cars are at the spec 1/4".
I do it the way Tim does it. I adjust the drag link to the point where it is zero or just out in front from zero. Then I lengthen one rotation and tighten the clamp. It might not be right on, but is as close as you can get it without bending the spindle arm.
- First Name: Art
- Last Name: Mirtes
I agree with Anthony's method. If front linkage is in good condition, I recommend 1/32 to 1/4 inch toe in. Keep in mind that one turn on the tie rod changes the toe in by about .22 inches.
Art Mirtes
Art Mirtes
