I thought I was done with my disk brake project on my 26 Touring but have a lingering question.
The hose from the remote reservoir is a bit long and I let the hose droop a little below the level of the master cylinder in the routing. Seems to make no difference and the system bled ok. Do you think this will create a problem?
Thanks,
Mike
Quick Question on Hydraulic Disk Brakes
Re: Quick Question on Hydraulic Disk Brakes
I don't believe that would be a problem if you were able to get the system fully bled. Ideally, every line in a system would be placed so that bubbles would rise to the highest point in the system. I doubt that's ever been accomplished.
- First Name: Ronald
- Last Name: Bakow
- * REQUIRED* Type and Year of Model Ts owned: 1915 Model T Touring
You will be fine as long as the air is out.
- First Name: craig
- Last Name: leach
Hi Michael,
Gravity being the weakest but most persistant force in the universe it shoud not be a issue unless it kinks over time. Check it once in awhile, you never know when the extra hose will come in handy.
Craig.
Craig.
