Head Lamp Rim Removal Tool
BLB27
First Name: Bruce
Last Name: Brakke
Post by BLB27 » Sun Jan 09, 2022 4:49 pm
How well does the head lamp removal tool (that is listed in Snyder's and Lang's catalogs) work.
I do note that one has a T-6575-T number and the other lists it as 1243. There is a significant difference in price. I wonder whether they are the same tool.
Last Name: Juhl
Re: Head Lamp Rim Removal Tool
Post by Oldav8tor » Sun Jan 09, 2022 6:00 pm
They look to me to be the same tool. It's designed to fit over the rivets to hold the rim while you push and turn. I've never used them for fear of scratching the rim.
I've never had any trouble getting my rims off - just push in with both hands and twist counterclockwise. If they haven't been off in awhile a little penetrating oil around the edge might help.
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Sun Jan 09, 2022 6:01 pm
I had great hopes when I bought the tool but had mixed results on 4 Model T’s even after working on the buckets and rims. I get the rims off better with my bare hands. Though the tool is uber stiff it slips off the rivet heads for me.
Post by DanTreace » Sun Jan 09, 2022 10:16 pm
The tool works for me on stubborn rims. Lots of penetrating oil first, then pad the arms with rag. The rag gives more grip and won’t scratch and works to wedge the tool snug.
Like the leverage the tool gives, plus can push a hip into the tool bar to get the reflector spring compressed , while twisting the tool bar with both hands.
Post by Mark Gregush » Mon Jan 10, 2022 12:05 am
If I have a stubborn one, take it off, lay face down on a piece of carpet or padding, push down from the rear and twist.
Post by Steve Jelf » Mon Jan 10, 2022 12:29 am
There's another tool for that purpose that works very well.
I made my own because I'm cheap.
http://dauntlessgeezer.com/DG112.html
Post by RajoRacer » Mon Jan 10, 2022 10:53 am
There is a diagram in the Ford Service Bulletins for making up a rim removal tool similar to Steve's without the hinge -it's a much better design than the current ones available - IMO.
Post by Norman Kling » Mon Jan 10, 2022 11:29 am
I made one similar to Steve's. It just has a loop on the end where Steve put the hinge. It works very well. I usually try to remove it without the tool, but if it is too tight, I use the tool.
If you are afraid of scratching the rim, use a thin rag such as an old T shirt between the tool and the rim. Trick is to pinch the rim tight so you don't slip off the rivets and push in with one hand as you turn with the other hand.
Post by TXGOAT2 » Mon Jan 10, 2022 12:01 pm
Try using a slightly dampened chamois.
Post by Original Smith » Tue Jan 11, 2022 10:33 am
What's wrong with using your two hands and pushing in and turning? It always works for me, and I don't mess up the paint either!
JohnM
Last Name: Michaelree
Board Member Since: 2010
Post by JohnM » Tue Jan 11, 2022 7:13 pm
The best tool is the one you have. Place a thigh of one leg against the front of the light. Hands on each side of the ring. Lean forward as if you are trying to push the car with your leg while rotating the ring counter clockwise. Hasn't failed me yet.
Alan Long
First Name: Alan
Last Name: Long
Post by Alan Long » Tue Jan 11, 2022 8:12 pm
I’m with Mark and remove the Bucket from the Vehicle, place it face down on insertion rubber, press down and turn
the Bucket. It gives more area to place the palms of your hands and push squarely. The Rim is stationary and the bucket rotates
Anti Clockwise. It still can be awkward but check that the bucket openings, and guide tracks are in good condition for the rivets
to pass over easily before reassembling making it all good for next time.
Alan in Western Australia
Post by Steve Jelf » Tue Jan 11, 2022 10:17 pm
Before reassembly, add candle wax.
