Support Forum
David Greenlees
- Last Name: Greenlees
- * REQUIRED* Type and Year of Model Ts owned: 1913 Model T racing car, 1924 Model T Depot Hack with original York #803 body.
Post
by David Greenlees » Sat Feb 19, 2022 5:55 pm
[image]
[/image]
Looking for any details about any of the the aluminum high-compression low heads that have been on the market place over the last 50 or so years. Details and photos of these heads are hard to find, other than it has been reported that the most recents ones manufactured are said to have a 6.0:1 compression ratio.
I'm looking for photos of the combustion chambers of any one of these heads which have been manufactured recently.
David Greenlees on Sat Feb 19, 2022 7:52 pm, edited 1 time in total.
Post
by TRDxB2 » Sat Feb 19, 2022 7:00 pm
Here is a comprehensive comparison of several heads done in 2011 I believe
http://mtfctulsa.com/Tech/heads.htm
You'll need to navigate through several pages to see it all
- compression ratios.png (104.58 KiB) Viewed 3873 times
David Greenlees
Post
by David Greenlees » Sun Feb 20, 2022 6:48 am
Kevin Pharis
Thanks for the links, I appreciate it.
Kevin Pharis
- Last Name: Pharis
Post
by Kevin Pharis » Mon Mar 07, 2022 11:54 pm
After pondering how to build a new Winfield head for several years, a little inspiration and curiosity yields something very similar to a Green. Better pics, or better yet measurements, and a little more patience could get a design that’s really close to an original...
David Greenlees
Post
by David Greenlees » Tue Mar 08, 2022 8:38 am
Kevin Pharis wrote: ↑Mon Mar 07, 2022 11:54 pm
Very nice work! Have you ever gotten involved with casting something like this? After having recast and machined several pre-WW1 engine blocks recently, the old-fashioned way with wooden patterns - modern cad design and core printing is the way I would do it from now on.
Have you even been involved with a casting with printed cores? Any chance you might may do a Winfield head? I've been thinking of talking with friend Lee Stohr at
https://www.stohrdesign.com/ about doing a Green head if I decide to go down that road.
Harry Lillo
- First Name: Harry
- Last Name: Lillo
- * REQUIRED* Type and Year of Model Ts owned: Speedsters, racers, depot hack, coupe
Post
by Harry Lillo » Tue Mar 08, 2022 10:04 am
Perhaps another option would be an original, never used Winfield head from the day the racer was shaking up the racing world?
It is interesting that Winfield never cast a water inlet in his head. He used two inlets on top of the head with a manifold arrangement
similar to an exhaust header to transfer coolant. I expect it reduced the water capacity in the head, but provided more equal cooling.
Harry
Kevin Pharis
- Last Name: Pharis
Post
by Kevin Pharis » Tue Mar 08, 2022 10:45 am
Harry Lillo wrote: ↑Tue Mar 08, 2022 10:04 am
Harry
Let’s see this mythical creature...
Art M
- First Name: Art
- Last Name: Mirtes
Post
by Art M » Tue Mar 08, 2022 11:27 am
Has the head design of the Hudson flat head six cylinder head from the early 1950's been studied. These cars were beating the rocket 88 Oldsmobiles in the stock car races. In the late 1980's I worked with the engineer who had worked on this Hudson engine. I wasn't smart enough to ask him about details. He passed away in 1993.
Art Mirtes
Harry Lillo
- First Name: Harry
- Last Name: Lillo
Post
by Harry Lillo » Tue Mar 08, 2022 11:31 am
Kevin,
I am in Panama right now so don't have ready access to get you pictures.
I purchased it a quite a number of years ago from another collector.
When I get home next month I will get you some pictures.
Harry
Kevin Pharis
- Last Name: Pharis
Post
by Kevin Pharis » Tue Mar 08, 2022 12:32 pm
As close as I’ve ever been to a real Winfield...
Les Schubert
- First Name: Les
- Last Name: Schubert
Post
by Les Schubert » Tue Mar 08, 2022 3:50 pm
Harry Lillo
- First Name: Harry
- Last Name: Lillo
Post
by Harry Lillo » Tue Mar 08, 2022 5:20 pm
Kevin,
That looks like the brother to my unicorn!!
Harry
David Greenlees
Post
by David Greenlees » Wed Mar 09, 2022 1:23 pm
Nice work, this is the way to do it today if you can. Saves a lot of work and the end product is superior to doing it the old fashioned way.
Not T related, but below is the most complex casting I've done to date. A new cast iron cylinder block for this 1915 Duesenberg racing car 300 CI OHV 16-valve four. More info and photos @
https://theoldmotor.com/?p=157435 and
https://theoldmotor.com/?p=20330
