26 t front body to frame mount missing
Topic author - Posts: 22
- First Name: David
- Last Name: Foley
- * REQUIRED* Type and Year of Model Ts owned: 26 touring 26 roadster
front body to frame mounts were removed does anyone have replacements or a drawing to fabricate from? Thanks for your help
Re: 26 t front body to frame mount missing
Haven't a drawing or part replacement, but here is a pic of what that front frame mount looks like.
Do you have one on the other side? You might need to make one mirror image of the other. Those are usually ok and attached to the body, so I don't think the vendors have them, but should not be hard to make for someone with the right tools, or possibly remove them from an existing body which is too bad to restore.
- First Name: Mack
- Last Name: Cole
I salvaged 1 a few weeks ago when I was making 1 cowl out of parts from about 5. I will go see if I can lay my hands on it and if I can ,just help me out with the shipping.
I found it,it has a cut from the grinder on the side,can be welded up,still very rusty with dirt and the rusty sheet metal still riveted to it.
- First Name: David
- Last Name: Foley
I do need both sides, the previous owner was going to hot rod it and had removed them, thanks for the picture helps to see what im looking for
- First Name: Will
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 26 Runabout
Here is a much-enlarged shot of the brackets in question. The photos are hampered by a metal channel used to support the body when it was on the rotisserie. The metal channel is marked by the red arrow.
??????? Looks like electrical metal channel ??? It comes in many sizes
reread Will's post, Frank
Are these what you need - recently listed on eBay so Hurry - seller is a good guy will take a reasonable offer - From CanadaDave Foley wrote: ↑Fri Mar 11, 2022 1:43 pmfront body to frame mounts were removed does anyone have replacements or a drawing to fabricate from? Thanks for your help
https://www.ebay.com/itm/284699164209?h ... 8A&vxp=mtr
and there they are, on a silver platter
