Pouring Babbitt using a Hempy cooper jig
Randall strickland
First Name: Randall
Last Name: Strickland
Post by Randall strickland » Fri Apr 08, 2022 7:14 am
Harry Lillo
First Name: Harry
Last Name: Lillo
Re: Pouring Babbitt using a Hempy cooper jig
Post by Harry Lillo » Fri Apr 08, 2022 10:07 am
Thank you for sharing this Randall.
Can you help me understand the purpose of spraying the jig with what
I assume was water after pouring the babbitt?
Harry Lillo
Post by Rich Eagle » Fri Apr 08, 2022 11:41 am
It is fun to see that after hearing about it for years.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Fri Apr 08, 2022 2:23 pm
He is not spraying the jig if you look closely, he is spraying the main web under the fixture to cool the block and chill the babbitt.
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Post by Charlie B in N.J. » Fri Apr 08, 2022 8:00 pm
Explain the peening please.
Post by Rich Eagle » Fri Apr 08, 2022 8:24 pm
"peening or compressing the babbitt by hammering is often specified.... to compress the babbitt in a bearing and harden it so that it will give better service."
https://www.911metallurgist.com/babbitted-bearings/
Erik Barrett
First Name: Erik
Last Name: Barrett
Post by Erik Barrett » Fri Apr 08, 2022 9:05 pm
When I pour these I pour from both sides using left and right hand ladles. The quicker you fill the mold the less chance of a cold shut. The water is sprayed to chill the babbitt as quickly as possible which preserves the quality of the metal. I have a helper ready with the squirt bottle handy. If there is a leak in the setup often it can be chilled with water and the pour salvaged. My molds are patterned after KR Wilson tooling but I use a smaller mandrel to give more room to bore for undersized cranks.
Post by Mark Gregush » Fri Apr 08, 2022 10:29 pm
I under cut my KRW arbor for pouring and have tried pouring with the block vertical. That seemed to work ok. Some people chill some don't.
Last Name: Hatch
Post by Dan Hatch » Sat Apr 09, 2022 11:24 am
To quote someone famous on here. “If you don’t peen the Babbitt, the crankshaft will do it for you.”
That will result in a loose bearing. Dan
