Clock mount question.
John Heaman
Topic author - Posts: 293
- Last Name: Heaman
- * REQUIRED* Type and Year of Model Ts owned: Canadian 1912 Ford Model T Touring
l purchased a vintage clock and it’s mounted on a plinth using its original mount and l don’t know how to remove it. I’m unable to contact the seller presently. Anyone with this style of clock could you enlighten me please.
I’m reading a book about anti-gravity. I just can’t put it down.
Re: Clock mount question.
Do you know it's maker's name. It may mount similar to this one.
https://www.sellingantiques.co.uk/photo ... 093458.jpg
Perhaps a twist will unlatch it.
It would be great to find patent drawings wouldn't it?
Dropacent
- Last Name: Morsher
If it has a little brass plug on the bottom edge, remove the plug and use a straight screwdriver to loosen from the mount.
John Heaman
- Last Name: Heaman
The clock case is perfectly smooth. The bezel unscrews to reveal ‘Made In USA’. I have an idea (except the seller forgot to send the key, but will after Easter), perhaps what l thought was the ‘slow/fast’ setting above the 12 is possibly a screw fastening the clock to the mount!?
Dropacent
I’ll bet that’s it.
John Heaman
- Last Name: Heaman
l know it’s not Timex because it wasn’t set for 10 to 2.
- First Name: Dennis
- Last Name: Seth
If it was a Timex you could call John Camron Swazey!
Well, if it's the one sold by Hemswell, they said they mounted it, so they should know how to dismount it.
That said, there are 4 screws holding the assembly into the housing (one screw is missing and will likely be located inside)
It has been many years since I've serviced one of these, but I seem to recall that the gizmo at "12" should be the fast/slow adjusting arbor, which is attached to a stamped brass gear which advances or retards the hairspring regulator pins and is adjusted using the key. FWIW, these were pretty much worthless in the '70s and only because I was an apprentice at the time would I even fool with one. No one in the trade earning a living would be able to get $25 to repair a $2 clock. Lots of them went to the dump. Fortunately, benign neglect allowed yours to escape that fate!
Don
- First Name: Don
- Last Name: Azevedo
- * REQUIRED* Type and Year of Model Ts owned: 5
- Board Member Since: 2003
Scott, I have a New Haven Clock that is very similar to yours. The fast/slow adjustment is in the slot located from 1:00 to 2:00. Use a key to turn the stem at 12:00 that secures a bar on the back of the clock. That bar has screws that attaches to the wood. Don Azevedo
Don
if that's the case, then I'm sure I've never seen this model and appreciate the interesting info. Always something new to learn. Thank you.
Larry
- Last Name: Gresh
John I have the same clock and can send you a picture of the back of it if you haven’t figured it out yet.
Larry
- Last Name: Gresh
Looks like you:
1. turn the bezel off counterclockwise
2Remove the four small brass screws holding the works in the case.
3. Remove the screw at the 12 o’clock position in the case which is probably holding it to the wood. Then push down on the case as it attaches to a clip on the bottom.
John Heaman
- Last Name: Heaman
Larry, l can’t thank you enough for your explanation and taking the time to photograph your clock! It’s a breeze with your information! Thanks again!! John
Dropacent
Wonderful pics, Larry. Nice accessory clock ! I’m going back in my memory brain, and I had one years ago just like it. I remember now making the mounting strip and the mounting screw before I sold it. I’ll bet originally it had a special mounting screw that would have a square drive, same as the winding stem. It likely would have had a shoulder near the threads of the screw that would have held it to the bracket. I doubt originally you would have had to remove the movement to install. I could see that as problematic for the original buyer. JMHO
Jay just sold a really neat clock, one I’ve never seen before, in person OR print.
Larry
- Last Name: Gresh
Tim,
I hope all is well with you!
You have a good memory! And I think you are right about the screw at the top. I never even thought about that or looked close enough to see that you could access the screw without removing the works since mine is missing that screw.
I hope John sees this as he will not have to remove the works to access that screw. If it is a square head, he will certainly need the key to remove it or a very small socket will work.
Dropacent
Another fingernail drawing. All good here, Larry!
Larry
- Last Name: Gresh
Found another one of these clocks sitting on the shelf this afternoon and wanted to confirm what Tim said. The screw has a hex head and the key removes it.
