Straightening rear end housings.
Erik Barrett
Topic author - Posts: 537
- First Name: Erik
- Last Name: Barrett
Building a couple rear ends for people. It’s amazing how many of them are bent. Like oil pans. I have never put one on my KRW jig that didn’t need some correction.
Ken Buhler
- First Name: Ken
- Last Name: Buhler
- Board Member Since: 2012
Re: Straightening rear end housings.
Out of 17 housings I straightened last year, 2 didn't need work.
Work honestly
Stay true to your word
Get the job done right
Stephen1915
- First Name: Stephen
- Last Name: Noll
- * REQUIRED* Type and Year of Model Ts owned: 1916 Coupelet
Erik, Would it be possible for me to send you 2 1915 housings to check/straighten?
Stephen1915
- Last Name: Noll
Ken are you doing this as a service as well?Ken Buhler wrote: ↑Mon Apr 18, 2022 10:05 amOut of 17 housings I straightened last year, 2 didn't need work.
Does that heat treatment cause the housing to become brittle? How do you put the proper temper into the steel?
Ken Buhler
- First Name: Ken
- Last Name: Buhler
I did them for my own inventory. I do not want to be in a competitive position with anyone established already. Shipping is always a factor.
Work honestly
Erik Johnson
- First Name: Erik
- Last Name: Johnson
Years ago, I saw someone cold straighten 1914 axle housings while they were on the car.
He set the wheels on an I-beam, wrapped chains around the housings and I-beam fore and aft of area he wanted to straighten, and used hydraulic pancake jack between the I-beam and housing, jacking and repositioning as needed until he was satisfied.
Erik Barrett
- First Name: Erik
Heating the tubes doesn’t bother the Ford steel tubes. I will straighten housings if you get them here. It’s $50 a pair.
- First Name: Dennis
- Last Name: Seth
Hey Erik...Here is a rear end that needs straightened!
Michael Peternell
- First Name: Michael
- Last Name: Peternell
Southern wide track?perry kete wrote: ↑Mon Apr 18, 2022 7:09 pmHey Erik...Here is a rear end that needs straightened!
Sorry! Couldn't help it!
She needs to get off that scooter and walk. That exercise would help.
Its no good has a crack in itperry kete wrote: ↑Mon Apr 18, 2022 7:09 pmHey Erik...Here is a rear end that needs straightened!
Erik Johnson
- First Name: Erik
That's a rare, southern wide-track.....
Alan Long
- First Name: Alan
- Last Name: Long
I had 4 large spigot bushes made up that slide into the housings where the Hyatt Bearing Sleeves go. Then after we believed
the housing were straight we bolted both housings together and offered up a 2” Diameter steel bar. This slid through all 4 bushes and exited the other end of the housings . This proved that all sleeve diameters were in perfect alignment.
Alan in Western Australia
Great information! Most of the ones I've used need to be straightened.
Erik Barrett
- First Name: Erik
Perry, I would have to use my big lathe for that one!
RGould1910
- Last Name: Gould
Bending the tube to align with the center casting bolt surface only works if the tube itself is sprung and you are straightening the bend. If the problem is the center section is sprung or was not riveted to the tube correctly, bending the tube will cause the roller bearings to be misaligned
One attempt to address this concern is to mount a large plug to the fixture which is held in the lathe to which the housing is bolted. The plug fits snugly into the inner bearing when the housing is bolted up.
The idea is to keep the bearing hole horizontal so that bending the tube won't misalign the bearing holes .
If the bolt surface of the housing does not bolt up evenly on the fixture with the plug inserted, the problem is a misaligned center casting and that should be addressed. I'll try to post a photo of the fixture later.
- Last Name: Seth
Darren J Wallace
- First Name: Darren
- Last Name: Wallace
I’m going to be the devil’s advocate here in a respectful way. I’m a 35 year tool and die machinist and a millwright. I believe by correcting these rear ends you guys are doing a great thing.
That being said, honestly, how many rear ends had alignment issues right out of the gate? We’ve all seen what a frantic pace old movie footage shows Ford employees going like Jack the Bear.
How many of these rear ends were checked to the accuracy of indicating them up in a lathe?
Trying to achieve a perfect alignment with a rear axle could be all for naught the moment you hit a pot hole or disturb the rear end with a hit or shock of significant force.
So really what acceptable amount of error in alignment is safe?
.001”?, .005”?, 1/32”?, 1/16”? I would be interested in knowing where one should draw the line.
Respectfully submitted.
Les Schubert
- First Name: Les
- Last Name: Schubert
I try for 1/16”
Erik Barrett
- First Name: Erik
I’m sure a lot of them were not perfect right out of the factory. But I like to have them as straight as possible when they leave my shop.
RGould1910
- Last Name: Gould
I've settled for .050" swing, but try to get less. By that I mean swing at the wheel end with the center casting end mounted in the lathe fixture.
Darren makes a very good point. I had to do extensive correction work to the centre castings on my 1912 clamshell diff because of cracks in the castings between the rivet holes. It is the only diff I have ever had to straighten. I assemble mine using a jig which holds the housings on the vertical. The axles present themselves off centre at the outside end at times. If I can wobble them enough that they would not bind on a roller bearing when inserted, I consider them good to go.
Welding the cracks in the clamshell centres warped the mating surfaces between them. I machined a stub to fit in the bearing tunnels and used this to mount the castings in the lathe. Both the mating surfaces and the thrust plate surfaces had to be dressed to true them. When the tubes were fitted. one side needed to be "adjusted".
