Installing Bumpers on a 1923 Model T
Unprr
Topic author - Posts: 291
- Last Name: Schmidt
- * REQUIRED* Type and Year of Model Ts owned: 1927 coupe, 1924 Model T pickup
Has anyone installed bumpers on a pre-bumper Model T.
The attached photo shows the parts, which may not be Model T. Along with the Model T in need of the bumpers.
The brackets from the car, to the bumper, were not included.
Any help, would be appreciated.
George
George
Re: Installing Bumpers on a 1923 Model T
With ends like that, they are like likely A model bumpers. T bumpers did not have bolts through eyes on the end of the bars. 26-7 mounting irons should work, but will need to be finessed to fit an earlier frame. There were multiple sets of accessory bars for earlier cars.
Tadpole
- First Name: Tad
- Last Name: Glahn
Here is an aftermarket rear bumper produced for pre-26 T's. It is secured under the body mounts in the rear and clamps around the frame towards the front.
Those look like 1928-'29 Model A bumpers. I believe some 1930 cars also used them. The radiator shell is 1928-'29 Model A passenger car. I suspect the Model A bumpers are wider and heavier than those made for the Model T. Mounting brackets would not fit the T frame. The Model A bumper bars would probably be adaptable to Model T mounting brackets.
- First Name: Austin
- Last Name: Farmer
What type of car is in the first picture? I have never seen anything like that before... I am new to the form however, so I am not the most experienced in identifying all of the cars.
I am assuming it is a Pickup?
That appears to be a Swiss Army car.
GG Gregory
- First Name: GG
- Last Name: Gregory
Those are for sure 1928-29 Model A bumpers and Radiator shell
George Mills
- Last Name: Mills
The front brackets are pretty much generic whether OEM or Western Auto. They have an over -under clip that sets on the frame and then a through bolt for an existing hole in the frame to secure them in place. Frame year doesn't matter.
The backs are similar, although I have never been able to mount a full width bar pre-market rear set of bracket irons on the Fordor with the spare in place. I believe the set of brackets I have may have started as a set of individual bumperettes...and then picked ups set of bars along the way before I rescued them.
Austin, hang around here too long and you will get to see all sorts of combinations of parts from various cars to make up a road going vehicle. Yes, it is a non factory made pick-up of sorts. This one has A model wheels, and unless my eyes deceive me, the front ones are a different size to the rears, reflecting the change to 19" wheels in the later A models. The A model bumpers will not look out of place with them.
- First Name: Dallas
- Last Name: Landers
Is the T hubs for wood wheels drilled for A wheels?
T hubs require an adapter to fit A wheels. The PCD of the A model wheels is greater than the 6 holes in a T wheel hub. The A model wheels also need to be spaced outwards.
- Last Name: Farmer
I guess whatever works! I like that it has a little "class" but still retains the Model T look.Allan wrote: ↑Fri Apr 29, 2022 7:50 pmAustin, hang around here too long and you will get to see all sorts of combinations of parts from various cars to make up a road going vehicle. Yes, it is a non factory made pick-up of sorts. This one has A model wheels, and unless my eyes deceive me, the front ones are a different size to the rears, reflecting the change to 19" wheels in the later A models. The A model bumpers will not look out of place with them.
- Last Name: Farmer
I think that one may need a bit of work...
Maybe he can use the bumper for his car!
