Removed 18 grams from the brake drum photos
Topic author - Posts: 1145
- Last Name: Gould
I was careful not to disturb stuff on the inside.
- First Name: Chris
- Last Name: Brancaccio
- * REQUIRED* Type and Year of Model Ts owned: 1909 Roadster 1915 Coupelet 1923 Coupe 1926 Touring
Re: Removed 18 grams from the brake drum photos
Richard, was it balanced after that?
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
MTFCA Webmaster
MTFCA Forum Admin
- Last Name: Gould
Forgot to add the balancing was done with the driving plate attached and after other stuff was done. It balances very well on a static balancer.
- Last Name: Gould
Yes Chris it was a back and forth job of removing stock and placing it on the balancer until there was no heavy side and the the brake drum/driving plate assembly came to rest without favoring a position.
Richard, did you take anything off the driving plate?
- Last Name: Gould
No Allen I only took stock off the brake drum. I did have have the driving plate attached of course but there was no place I could take off any appreciable amount from it.
- Last Name: Gould
Richard, I asked because sometimes it means less of a hole has to be dug in the drum. If I find that much needs to be removed I juggle the driven plate around to a different position to see if that makes any difference to the out-of-balance before starting o the grinding.
- Last Name: Gould
I rotated the driving plate to where there was the least run out of the tailshaft before balancing.
