Fuse Location
BLB27
First Name: Bruce
Last Name: Brakke
Fuse Location
Post by BLB27 » Mon May 02, 2022 8:33 pm
Where is the best location for a fuse to address possible shorts?
Re: Fuse Location
Post by DanTreace » Mon May 02, 2022 8:52 pm
The 'best' is likely nearest the battery voltage source, so put it on the yellow wire coming off the foot button starter switch.
Or the 'best' for handy use is on that big yellow wire, but at the terminal block. That way you can just take apart the fuse holder, don't have to remove the fuse, just separate it, and all power to the dash is voided.
mtntee20
First Name: Terry & Sharon
Last Name: Miller
Re: Fuse Location
Post by mtntee20 » Mon May 02, 2022 10:29 pm
It might be good for new recruits and entertaining for others to hear the seasoned among us, relate what SIZE (amperage) fuses to use in the previously mentioned/shown fuse holder.
Let the debate begin......
Re: Fuse Location
Post by TXGOAT2 » Mon May 02, 2022 10:40 pm
It would be convenient to add a fuse at both locations. As to fuse rating, electrical load and wire size should determine that.
Last Name: Patrick
Re: Fuse Location
Post by jiminbartow » Mon May 02, 2022 10:42 pm
Mine is under the car next to the starter button. Jim Patrick
First Name: Henry
Last Name: Lee
Re: Fuse Location
Post by Henry K. Lee » Mon May 02, 2022 10:53 pm
Debates, disagreements, for the great minds are only a moment in time. If no fuse is used.., it is not a smoke check but a condition of very small particles of black carbon a drift in the atmosphere. Just like the term.., "Flash Light" or "Torch" in the UK. Like what were you thinking...., It is a "Darkness Penetrator"!
Hank
Re: Fuse Location
Post by TXGOAT2 » Mon May 02, 2022 11:03 pm
Get Fuz-E-Liminator now! Instantly turn that unsightly, confusing nest of wires under your hood into shining beads of real copper! Impress your friends with blue fire and thick puffs of white smoke! ..... Fits all cars..... $2.98.. Order NOW* ! * Use only as directed. Not responsible for uncontrolled combustion, insurance cancellations, citations, or tow bills.
Re: Fuse Location
Post by Steve Jelf » Mon May 02, 2022 11:25 pm
I think Ron Patterson is pretty good with electrical stuff. He says put a 25 amp fuse where the yellow wire connects to the starter switch.
Last Name: Hjortnaes
Re: Fuse Location
Post by DHort » Mon May 02, 2022 11:37 pm
Mine is under the hood like in picture #3. Easily accessible. I have 25amp and 30 amp fuses in the box, but if Ron said 25 amp, that is what I have.
Petrah Phyre
First Name: Sean
Last Name: Pownall
* REQUIRED* Type and Year of Model Ts owned: 1926 Speedster
Re: Fuse Location
Post by Petrah Phyre » Tue May 03, 2022 7:33 am
If you do happen to let the smoke out of your wires, they have been making a smoke machine for a while. They are not cheap, but can help if you've made this mistake. Just search for 'smoke machine' in your search engine. :D
Re: Fuse Location
Post by Jerry VanOoteghem » Tue May 03, 2022 1:27 pm
Why 2 fuses in the same wire?
Re: Fuse Location
Post by Original Smith » Tue May 03, 2022 1:59 pm
Never have had an issue with Ford's original design.
Re: Fuse Location
Post by Scott_Conger » Tue May 03, 2022 2:02 pm
which is precisely why FORD products still do not have fuses
:roll:
Last Name: Juhl
Re: Fuse Location
Post by Oldav8tor » Tue May 03, 2022 2:31 pm
I've been playing with electronics since I was a kid, had a Ham license for over 50 years. Fuses are installed to protect wires carrying substantial current. For my T, I chose to install an automotive circuit breaker in the equivalent of the "yellow" wire mentioned previously. Maybe Ford chose not to use them, but as someone who has seen the results of a melted wire, I see no issue with using one. My '17 never had an electrical system per se... I've installed a starter, electric LED headlights, sidelights and tail lights, so I've felt free to design an electrical system that suits my needs.
First Name: Henry
Last Name: Lee
Re: Fuse Location
Post by Henry K. Lee » Tue May 03, 2022 2:58 pm
Until it happens and burns to the ground.., the non believers will never change. I think the most intelligent of people believe in a proactive approach. Now let’s see how many read all those pink elephant clauses and annual “changes to your policy” fliers with your premiums for antique car insurance. Car fire clause…,”Vehicle most have protective measures in prevention of fires, ie, fuse/and/or quick accessibility to disconnect battery power”. Don’t forget.., must carry a modern and size appropriate ABC fire extinguisher!
Now go and fight their lawyers in the court of law with your cheap lawyer…., claim denied!
Hank
Re: Fuse Location
Post by DanTreace » Tue May 03, 2022 3:04 pm
Hank
Well stated ;)
Pulled these photos off the forum in the past. And I've experienced the amp wire burning in my first T, as teen. No fun to see smoke coming from behind the dash! :shock:
Re: Fuse Location
Post by DanTreace » Tue May 03, 2022 3:08 pm
And, the original F.A system for battery start included a FUSE in that Yellow wire!
Don't know why it wasn't kept in the circuit for later Ts. Guess Henry wanted to save a few pennies, or else felt anyone who wanted a battery in his magneto Ford to fend for themselves :lol:
Quickm007
First Name: Mario
Last Name: Brossard
Re: Fuse Location
Post by Quickm007 » Tue May 03, 2022 4:00 pm
Personnally I have a Master Disconnect Switch on all my T's. This disconnects all electrical circuits with a flip of a lever and eliminates battery drain, prevents fires, and guards against theft. Mounts anywhere. UL approved for 6 or 12 volt batteries, Heavy duty. I bought it at Lang's
Super Mario Bross ;)
1911 Touring
1914 Speedster
Eric Sole
First Name: Eric
Last Name: Sole
* REQUIRED* Type and Year of Model Ts owned: 1927 Roadster
Re: Fuse Location
Post by Eric Sole » Tue May 03, 2022 4:55 pm
I mounted a master disconnect switch. It's under the seat and I cannot get to it while seated so if anything were to short-circuit while driving a fuse would still be a handy thing to have installed and protecting the circuit.
