Calling all knowledgeable 26/7 Touring Wood People!!
Topic author - Posts: 1158
- Last Name: Govoni
I need some help identifying some wood from an older wood kit that came with my car. First a big thank you to Tom Miller. He was able to help with several parts.
Now on to what I'm trying to figure out. Each part was labeled T2726T and had a number 1-16. I'm trying to take the list from FORD WOOD and match up the numbers so I can use their diagram and see where they go. Here is what I have. That last piece of wood labeled T2627 T6 is the same shape as the other two labeled T2727 T6 but a lot thiner.
and what I have Identified on the FORD WOOD list
Can someone tell me that for example T2627 T7 is number 603 and 604 Etc....
Thank you so much.
Thank you so much.
- Last Name: Hatch
Re: Calling all knowledgeable 26/7 Touring Wood People!!
You may want to find a T Body parts book. They have the wood shown in them.
- Last Name: Govoni
I have this book.
Looking at the 26/27 picture is does show some wood but not the small parts I need.
Unless there is another book that I don't have.
- Last Name: Govoni
There has to be someone out there working on a 26/27 Touring. I can't be the only one.
- First Name: Jonah
- Last Name: D'Avella
I am, but I will not be able to help since I am as clueless as you are.
- Last Name: Govoni
Jonah, I'm going o try to give Ford Wood a call and hope they can help. Not that many parts but still hard to figure it all out.
- Last Name: Killelea
Wish I could help. I have a 26-27 body on a 21 frame. It came with a wood kit from JC Whitney and I haven't opened it up. Don't have time and it's in the back of the garage with tons of new bathroom cabinet stuff that is getting ready to go in to 2 new bathrooms. Progress interferes with progress.
- First Name: Doug
- Last Name: Adams
- * REQUIRED* Type and Year of Model Ts owned: 1921 Roadster Pickup, 1926 Touring
The top two pieces (-7) should match up with 603 & 604 in the list. The notches are for clearance with the door striker hardware.
