HUBCAP FIT on WIRE WHEELS
Professor Fate
Last Name: S
* REQUIRED* Type and Year of Model Ts owned: '23 and '26
Post by Professor Fate » Fri May 13, 2022 6:57 am
Is there an easy way to form/spread the tabs on '26-'27 wire wheel repro hubcaps? They fit too loosely right out of the wrapper. I need to spread the tabs and was hoping there's a better way than just mind numbingly bending tabs individually one at a time. Is there anything that is correct size I can press the hubcap over to spread the tabs????
________________
**FATE**
Re: HUBCAP FIT on WIRE WHEELS
Post by TXGOAT2 » Fri May 13, 2022 8:17 am
I believe you need to remove each wheel and insert the hupcap into the wheel, then use any handy tool to reach inside the hub bend 4 of the tabs outward to secure the cap. Hold the cap firmly against the wheel from the outer side and press the tabs back. It is not necessary to bend all the tabs back. Just bend 4 of them back, at 12, 3, 6, and 9 o'clock. The unused tabs can be used later if you need to remove and replace the cap for any reason. A length of 1/2 " wooden dowel makes a good tool, but any similar item will work.
Post by speedytinc » Fri May 13, 2022 8:26 am
Get the 4-6 tabs tight as possible. Its real hard to get them tight enough to not rattle. I like to add some ultra black from the inside to keep them from rattling. I have seen some guys wrap a bit of fishing line around the outside between the wheel & underside of the cap lip to eliminate the loose rattle.
Professor Fate
Last Name: S
Post by Professor Fate » Fri May 13, 2022 8:50 am
Ok. Thanks. Never thought about pulling wheels off.
I think I was fixated on how loud the car would be going down the road with rattling hub caps.... hideous for sure!! Lol!!!!
________________
**FATE**
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Fri May 13, 2022 9:12 am
Once I have bent over 4-6 tabs I also add a drop of window caulk at the bent over tabs so they do not rattle.
TFan
First Name: Jim
Last Name: Riedy
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster
Post by TFan » Fri May 13, 2022 9:33 am
I did a kinda period correct fix on mine. I had some mason jar rubbers that I cut the tabs off of and glued to the inside of the hub opening then installed the caps bending four or six of the tabs over into the rubber, been a year now and so far no rattles. Jim
Post by Norman Kling » Fri May 13, 2022 4:27 pm
I like to position the spare tire on the carrier with the valve stem up. This way rain will not get into the rim through the valve stem. So I place he caps to be read when the wheel is in that position. I haven't used anything to seal the caps on the wheel. Just insert and bend a few of the tabs.
Professor Fate
Last Name: S
Post by Professor Fate » Fri May 13, 2022 7:24 pm
Got 'em all installed. Used ultra black and a long brass rod.
Thanks again
________________
**FATE**
Ed Baudoux
First Name: Edward
Last Name: Baudoux
Post by Ed Baudoux » Fri May 13, 2022 8:25 pm
With the wheel off, bend 4 or 5 tabs. Then use a rubber o-ring around the hubcap from the visible side. They won't rattle. The wheels on our Fordor are black, and the o-rings are almost invisible.
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
Scott C.
Last Name: Clements
Post by Scott C. » Sat May 14, 2022 1:09 am
I have been considering putting o-rings on mine. Glad to hear that it does work!
Professor Fate
Last Name: S
Post by Professor Fate » Sat May 14, 2022 1:23 pm
Inspected the caps today. All are tight and not turning due to the RTV goo that was applied during install. I should be fine now. 😉
20210918_104823 (1) (1).jpg (10.31 KiB) Viewed 2284 times
________________
**FATE**
