What perch is this?
csnailnrun
First Name: Ryan
Last Name: Snellen
* REQUIRED* Type and Year of Model Ts owned: 1912, 1919, 20's FrankenT
What perch is this?
Post by csnailnrun » Sat May 14, 2022 9:37 pm
I picked these up at Luray confident they were the tall perches for a large drum axle. I believe those are straight up, not curved like these.
Who knows what I have and what they go to?
Dropacent
Last Name: Morsher
Re: What perch is this?
Post by Dropacent » Sat May 14, 2022 9:50 pm
Ryan, they are for accessory rear shocks. Maybe Dreadnaughts, maybe something else.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sat May 14, 2022 10:13 pm
Funky like the stink on a monkey!
Post by TRDxB2 » Sun May 15, 2022 12:19 am
Opps they are NOT large drum rear perches for Hassler shocks. This is
Post by Allan » Sun May 15, 2022 12:25 am
KW had similar perches for their accessory shock absorbers.
Post by Wayne Sheldon » Sun May 15, 2022 1:30 am
The standard perches for the large drum axles are shorter (not taller!) than the common earlier small drum axle perches.
These are for accessory shock absorbers as others have said. However, notice, that the bolt and perch directions are not correct for the large drum pancake Hasslers. So they are for one of the dozens of other shock absorbers made and sold for model Ts back in the day.
Actually might be a good find. I don't know about now? But it used to be common to find the shock mechanisms missing these mounting perches. Someone may be looking for those?
Interesting? While I was typing? The photo I was referencing disappeared?
Post by TRDxB2 » Sun May 15, 2022 1:45 am
I started thinking about that the shackle hole & bolt where facing in opposite directions (telepathic event?) so I deleted the photo and posted the Hassler
I'm sure its for these coiled spring shocks
3-29 ACME 046.JPG (37.12 KiB) Viewed 2108 times
3-29 ACME 045.JPG (49.49 KiB) Viewed 2108 times
3-29 ACME 047.JPG (58.95 KiB) Viewed 2108 times
Post by Wayne Sheldon » Sun May 15, 2022 6:41 am
Frank B,
And I just thought I was going crazy!
I knew I saw the photo, then after I posted my comments, the photo was gone!
No worries. Besides, I needed the laugh today.
1915ford
Last Name: Cameron
* REQUIRED* Type and Year of Model Ts owned: 1909touring 1915 touring
Post by 1915ford » Sun May 15, 2022 10:19 am
Fun stuff but i would suggest you think long and hard about using them on a car you drive. Think about what happens when they break. This is not ford vanadium steel. This kind of part has caused fatal accidents before. Perhaps they are better on display rather than on the road.
