Would appreciate any help and information regarding this carburetor.
1) Choke plate?....located under intake mouth, one side is solid, other side is open, can be swung side to side....is this the choke?
2) Plunger that is spring loaded....what does this do?
3) Dial, can be rotated clockwise and counterclockwise, does this control the fuel/air mixture?
3) Dial, is clockwise lean, is counterclockwise rich?
4) What is this and what does it do?
Breeze Carburetor
- First Name: Henry
- Last Name: Lee
Re: Breeze Carburetor
Hey Jay,
#2 is a flooding push down on the float to give more wet fuel for starting.
#3 is a fuel mixture.
#4 is a poppet valve, some were used for a throttle but since you have one seen close to the intake mount, they used this as an anti-backfire.
Hope this Helps,
Hank
Hope this Helps,
Hank
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Jay- I have a manual. PM me your e-mail address and I will forward a copy. Most common on model 20 Hupmobiles- what is this one on?
John E. Guitar
- Last Name: Guitar
- Board Member Since: 2012
This article goves some information. I picked up one of the horizontal ones a few years ago but I've got no idea what it's from.
- First Name: Henry
- Last Name: Lee
I believe John has you covered Jay!
Hank
Hank
jaybee47
Topic author - Posts: 344
- First Name: jay
- Last Name: bolante
- * REQUIRED* Type and Year of Model Ts owned: 1922 Runabout
Many thanks to all for the help and education.
