Run Bd rod attachment.
Campbell Tellman
First Name: Campbell
Last Name: Tellman
* REQUIRED* Type and Year of Model Ts owned: 1916 Ford Touring
Post by Campbell Tellman » Sun Jun 05, 2022 5:04 pm
Hey All!
We are starting on a 1916 touring car. The rods between the running board supports have mismatched bolts. I wonder if someone could post a picture of the correct hardware. Maybe a description would do.
Thanks in advance.
Campbell Tellman
Beaufort, NC
Re: Run Bd rod attachment.
Post by Mark Gregush » Sun Jun 05, 2022 10:35 pm
You mean the truss rods that run between the running board irons? If so, one is straight across, the other has a dip in it to clear the torque tube/radius rods.
Post by Allan » Mon Jun 06, 2022 12:27 am
Campbell, do you mean the threaded rods have mis-matched NUTS? In my experience, this is one place where plain hex nuts were used, with no split pins.
Campbell Tellman
Last Name: Tellman
Post by Campbell Tellman » Mon Jun 06, 2022 6:02 am
I have since learned they are the truss rods. One straight and one with a dip. I believe 1/2 inch stock. I have some square nuts and some hex nuts on this car so that is why I am wondering the correct fastening.
Thanks,
Campbell Tellman
