Is This a Good Substitute?...
Last Name: House
Post by George House » Fri Jun 10, 2022 9:43 am
I see by an oil pool underneath the crankcase oil drain that my often used crush washer failed. Cannot find a replacement in small town hardware and auto parts stores but did find neoprene washer that’s a tight fit on the oil drain plug. Would this be a long term fix ?
Re: Is This a Good Substitute?...
Post by Rich Eagle » Fri Jun 10, 2022 10:04 am
Almost any seal material will work. I often used a 1/16" or thicker paper gasket. It's just oil.
mtntee20
First Name: Terry & Sharon
Last Name: Miller
Post by mtntee20 » Fri Jun 10, 2022 10:08 am
George,
Did you look for a copper washer? If you are unable to find a proper fit, make your own out of copper sheet. The only critical dimension is the inside diameter hole so it fits properly on the drain plug.
Good Luck,
Terry
Post by Original Smith » Fri Jun 10, 2022 10:14 am
Copper is the only way to go. I think I've bought those from Lang's.
Last Name: House
Post by George House » Fri Jun 10, 2022 10:19 am
Thanks to all. Good advice. I’ll make a washer out of thick gasket material and order a few next time I need a shipment from a vendor...🙏
John Heaman
Last Name: Heaman
Post by John Heaman » Fri Jun 10, 2022 10:39 am
I use string.
Last Name: Wrenn
Post by TWrenn » Fri Jun 10, 2022 12:14 pm
Me too and yes Langs has them. Or at least they used to. Nowadays my first question to any vendor is if they even HAVE it in stock!
Post by Scott_Conger » Fri Jun 10, 2022 12:49 pm
I am a Stat-O-Seal convert
I use them on pan screws, transmission door, and drain plugs...even modified the OD on one to seal the low-band adjuster. For the first time since I entered the hobby, I have cars which will rarely drip a drop of oil. Seriously...I can't recommend these things enough
they are moulded-in-place o'rings which have an aluminum washer which limits the crush on the oring to the exact designed compression...they simply work (and they are reusable, too)
https://www.pegasusautoracing.com/produ ... oduct=3245
Last Name: House
Post by George House » Fri Jun 10, 2022 1:08 pm
Very good Scott. Typically great advice from you. And I use feed sack string too, John, with 4-5 wraps around the bolts of the bottom pan inspection cover. 😁🇺🇦
Post by John kuehn » Fri Jun 10, 2022 1:13 pm
Ace hardware has copper washers.
Last Name: House
Post by George House » Fri Jun 10, 2022 2:07 pm
John, Ace Hardware might advertise they sell copper washers but Ace Hardware in Lockhart doesn’t sell them. That’s where I bought neoprene washers of the right I.D.
Post by Wayne Sheldon » Fri Jun 10, 2022 4:38 pm
George,
Good Luck,
Terry
Years ago, I had a pan that had an about an inch square piece of copper sheet with a tight fitting hole in the center to fit the plug. the corners were wrinkled and bent, but otherwise sticking out. It was on my engine when I got it, and on the engine for years after I got it running! It was a bit awkward to remove and replace as only one pair of hex sides was reachable by wrench, but not that difficult. I left it and worked with it for years as part of the car's history.
Worked just fine.
RGould1910
Last Name: Gould
Post by RGould1910 » Sat Jun 11, 2022 9:02 am
I've used a leather washer ro cure a stubborn leak.
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Sat Jun 11, 2022 9:47 am
RTV works as well. I recommend one of the big pump tubes to maximize loss though.
Dennis_Brown
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Post by Dennis_Brown » Sun Jun 12, 2022 11:21 pm
HARBOR FREIGHT sels a box of multiple various sized copper washers. Lots of places you can use them. They used to be 10 to 11 dollars.
