How do you...
NU2theT
Last Name: Wendt
How do you...
Post by NU2theT » Tue Jun 14, 2022 9:15 pm
connect this little bugger through the leather pieces into the lower hood ends. I do not have any tool small enough to flatten the little supplied rivet.
Any input would be great and Thanks in advance.
Last Name: Humble
Board Member Since: 2006
Re: How do you...
Post by Humblej » Tue Jun 14, 2022 9:40 pm
Support the rivet head on a buck, use a center punch to flair the rivet, then a ball peen hammer to form the mushroom.
Re: How do you...
Post by TRDxB2 » Tue Jun 14, 2022 9:53 pm
The proper tool is a rivet clincher. It is designed to role the edges of the tube rivet over (used on Model T ignition switch rivets). You could try to use a some punches, one to spread the tube and the other to flatten - chance of success about 40%. Or just replace the tube rivet with a split rive (washer optional).
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Re: How do you...
Post by MichaelPawelek » Tue Jun 14, 2022 10:09 pm
Note….You don’t rivet them on the way they come out of the package. They are folded where the rivet goes through 4 pieces.
Last edited by MichaelPawelek on Tue Jun 14, 2022 10:22 pm, edited 2 times in total.
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Re: How do you...
Post by MichaelPawelek » Tue Jun 14, 2022 10:10 pm
This is the proper fold.
NU2theT
Last Name: Wendt
Re: How do you...
Post by NU2theT » Thu Jun 16, 2022 5:43 pm
Thanks for the pictures and that piece of paper work...I used to have that somewhere when I opened the package last year, per usual just getting to it now. I will try Langs ect for that rivet punch.
Last Name: Juhl
Re: How do you...
Post by Oldav8tor » Thu Jun 16, 2022 8:47 pm
I just applied a little silicone adhesive on both sides and clamped it in place with a small wood block on either side. Two years on the leather is holding great.
OilyBill
First Name: William
Last Name: May
Re: How do you...
Post by OilyBill » Thu Jun 16, 2022 10:19 pm
An EXCELLENT source for rivets and the proper punches and tools to install them is "Hanson Rivet and Supply Co" of Pacoima, California. Their phone number is 818-485-0500. If you use the correct tools for the rivet you need to install, it will be done in 5 seconds, and will look perfect.
Or you can half-mule it, and look at those results for the next 40 years.
It's your choice.
