Painting New Aluminum Head
Topic author - Posts: 8069
I need to paint a new aluminum head. Any suggestions appreciated.
- Last Name: Tannehill
Re: Painting New Aluminum Head
Pat, I painted one about 6 months ago but considered an etching acid first. Then I decided to just use a high heat epoxy instead. So far no change in color or adherence.
Polish it and then clear coat, if desired, with high temp paint. Its easier than you think the process is simple, you need to be aggressive. Start with a grit heavy enough to remove casting bumps and marks, then move up to the next grit to remove the scratches made by the previous grit, repeat the process till your at 600 grit. Then clear coat with 2000 temp.
On a visit to see Elvan Townsend (he made many of the aluminum castings accessories and speedster builder the BULLET), I purchase this water outlet from him, when I mention polishing the letters, he proceeded to show me. Started with a medium coarse file to a fine one then sand paper. --
That aggressive approach helped me proceed on my first attempt. This was done by hand, in about 4 hours. I was a bit cautious not knowing what to expect. Could do it now in 2-3hrs --
I intend to do a aluminum hogs head, I started to see how it would go with 100 grit just to see what to start with
This Z head has a cosmetic good finish and no corrosion. The engine is one of the darker shades of green, and the paint is in good, so I'd rather go ahead and paint the new head rather than polish it.
babychadwick
- First Name: Chad
- Last Name: Azevedo
Zinc chromate primer will help to prevent electrolysis and chipping
You do need an etch primer suitable for aluminium as a base coat. After that, any usual paint will do. I use ordinary oil based enamel.
pron022020
- First Name: Tyler
- Last Name: Prondzinski
Either etching primer or epoxy will be a fine primer on aluminum.
Chris Haynes
- First Name: Chris
- Last Name: Haynes
- * REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
Blast the head and use Zinc Chromate paint. Nothing else sticks to aluminum.
Racer_22
- Last Name: Prus
- * REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1912 torpedo, 1914 touring, 1919speedster, 1921 touring, 1922 touring 1925TTsemi, 1926 pickup, 1926 roadster
- Board Member Since: 2004
Paint with the paint of your choice. I manufacture the P aluminum high compression head. We use Duplicolor engine paint in our shop with no problems. Don't try to over engineer the project. Paint and Go. Have fun.
Been Here Before
- First Name: George John
- Last Name: Drobnock
Paint generally does not last long. Why not just have an anodized aluminum cylinder head ?
