10 Tooth Driveshaft Pinion Gear
Topic author - Posts: 224
- Last Name: Wilson
- * REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
Just sorting through some parts that I bought at one time and found what I think is a Model T 10 tooth pinion gear. It looks to be in pretty good shape except for some surface rust. I would appreciate it if someone would confirm that this is in fact a Model T pinion gear. As can be seen in the pictures, there is a divot on the back of one of the teeth and another divot on front of the gear with either a 9 or a 6 stamped beside it. What your call?
- Last Name: Juhl
Re: 10 Tooth Driveshaft Pinion Gear
Looks like one - here is a photo that might help.
The divot on the back is where the hardness of the gear was tested when it was made. A Brinnell mark. The divot on the front face is "damage". Shows signs of use, but probably still got life in it. Looks like a Model T pinion to me. That's my O'Pinion
- First Name: Joseph
- Last Name: M
Jerry VanOoteghem wrote: ↑Thu Jun 30, 2022 3:03 pmThe divot on the back is where the hardness of the gear was tested when it was made. A Brinnell mark. The divot on the front face is "damage".
Not necessarily. The page below is from the Ford Service Bulletins, published by Ford Motor Company of Canada, and it directly references the mark on the gear. One may very well be a mark from hardness testing, but the one in the center of the tooth would correspond to the Service Bulletin.
Cool!Pep C Strebeck wrote: ↑Thu Jun 30, 2022 3:37 pmJerry VanOoteghem wrote: ↑Thu Jun 30, 2022 3:03 pmThe divot on the back is where the hardness of the gear was tested when it was made. A Brinnell mark. The divot on the front face is "damage".
- Last Name: Wilson
Thanks Pep. I had seen that reference to the Service Bulletin before. It is very possible that this pinion came from a Canadian built car considering where I live and most of the T's in this area, including the one I own now and one previous one, are Canadian built cars. There seems to be no end of differences, from wheels and spokes, to Touring back seat cushions and of course Robertson screws, between the US and Canadian built T's. I will clean this gear up a little to see if there are any other markings.Pep C Strebeck wrote: ↑Thu Jun 30, 2022 3:37 pmJerry VanOoteghem wrote: ↑Thu Jun 30, 2022 3:03 pmThe divot on the back is where the hardness of the gear was tested when it was made. A Brinnell mark. The divot on the front face is "damage".
That divot looks to be machined, like ones on gears I have on the shelves. Hardness testing usually leaves just a small pin prick like a light centre punch mark. Perhaps it had another purpose. Or perhaps the machined divot has a pin prick within?
- Last Name: Wilson
Hi Allan, There is a pin prick mark 180 degrees across from the divot with the 6 (or 9) beside it. It is much smaller and I didn't see it until I cleaned the gear up with a wire wheel. Would that number be an indication of the hardness?Allan wrote: ↑Thu Jun 30, 2022 9:11 pmThat divot looks to be machined, like ones on gears I have on the shelves. Hardness testing usually leaves just a small pin prick like a light centre punch mark. Perhaps it had another purpose. Or perhaps the machined divot has a pin prick within?
David, that sounds more like a hardness test mark. I presume the 10 stamp is for 10 teeth, but have no idea what the others are about.
- Last Name: Wilson
The pin prick comes from a Rockwell hardness test. These gears were tested with a Brinell hardness tester, that uses a ball indenter. Rockwell testing is for higher hardnesses, Brinell is for softer materials.Allan wrote: ↑Thu Jun 30, 2022 9:11 pmThat divot looks to be machined, like ones on gears I have on the shelves. Hardness testing usually leaves just a small pin prick like a light centre punch mark. Perhaps it had another purpose. Or perhaps the machined divot has a pin prick within?
Jerry, my experience comes from watching the fellows in my favourite machine shop hardness testing alloy heads after they have been overheated. If they are too soft, they are not worth working on. This is soft material, and the testing tool leaves the small centre punch mark referred to. It seems counter intuitive for a ball type test on harder materials like a steel pinion gear. Rather than just a falling weight for the head testing I mentioned. Such a test on a pinion gear would require a much more robust testing tool. I need further education, again!
My experience comes from 35 years in manufacturing. Trust me, it's a Brinell mark.Allan wrote: ↑Fri Jul 01, 2022 8:00 pmJerry, my experience comes from watching the fellows in my favourite machine shop hardness testing alloy heads after they have been overheated. If they are too soft, they are not worth working on. This is soft material, and the testing tool leaves the small centre punch mark referred to. It seems counter intuitive for a ball type test on harder materials like a steel pinion gear. Rather than just a falling weight for the head testing I mentioned. Such a test on a pinion gear would require a much more robust testing tool. I need further education, again!
