Sidelight reflectors
Bobbbenner
First Name: Bob
Last Name: Benner
* REQUIRED* Type and Year of Model Ts owned: TT 1924, touring 22
Post by Bobbbenner » Wed Jun 29, 2022 5:12 pm
How can I rejuvenate the reflectors in my sidelights and rear kerosene light?
Should I sand/smooth the back and paint using a high sheen silver?
Right now I’ve got Alumlnum foil pieces for reflection.
What have some of you done?
On another note. If my 22 touring has only kerosene sidelights and a kerosene tail light, does that indicate that it was originally sold without a starter?
It has a starter now.
Altair
First Name: David
Last Name: Menzies
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring and 1915 Touring both Canadian models
Board Member Since: 2012
Re: Sidelight reflectors
Post by Altair » Thu Jun 30, 2022 5:34 pm
The answer would be yes if it came from the factory that way but a PO or dealer could have installed them after the fact. Installing the side lights for a nonelectric T applied up to 1926 however there were few. I have a 26 touring with electric start however I have installed kerosene side lights. The original brackets were cast steel and the repro are brass. I installed them as a novelty just because I had them in a box.
Last Name: Tannehill
Post by JTT3 » Thu Jun 30, 2022 6:11 pm
1 wonder if small glass round mirrors could be bonded in the back as a reflector? Just a thought, I don’t know if they could stand the heat though.
Last Name: Hatch
Post by Dan Hatch » Thu Jun 30, 2022 7:07 pm
Reflectors were silver plated. You can try polishing them. Find some Wrights silver polish. it MUST be polish for silver plate. You can polish the silver off very easily. You can also replate them. Dan
Post by Allan » Thu Jun 30, 2022 8:50 pm
Bun style lights on a 1922 would have had steel innards. I have never found evidence of any plating on the reflectors, other than unpolished nickel on the 'Divers helmet' round type reflectors on the 1915 lamps. The best preserved square ones I have ever unearthed seemed to be raven finished on the outside, [the bit which is never seen when installed] but all the others have been rusty to varying degrees on the burner side. If you are looking to light the burners, it may be best to have the reflectors electro zinc plated. This will stand the heat, will reflect somewhat, and may even be the correct finish.
I paint mine gloss white and run electric bulbs.
