Painting Wire Wheels by Brush?????????
Topic author - Posts: 892
- First Name: Bruce
- Last Name: Brakke
I would like to get comments about painting wire wheels by brush. Is this practical, type of paint, etc.?
- Last Name: S
Re: Painting Wire Wheels by Brush?????????
I used this product on my wires and the car. The high flow tip allows for you to lay the paint on uniformly and much less apt to run, and it's dry to touch in 90 mins.
I highly recommend this stuff.
________________
**FATE**
**FATE**
I have been a champion for brush painting for a long time. Slow drying enamels can flow out as nice as any spray. You can coat evenly with a brush while a spray comes from one side. Enamels will not chip as easily on wheels as harder paints. Wheels flex more than we often realize.
Go for it.
Go for it.
Did by Brush using finish is hard. The color of the wheel looks like its picture and not the paint chip. The paint flows well
In some ways brushing is a better way to do it than spraying. Unless you are methodical in counting spokes, attacking form 4 different angles on each spoke, there is a good chance there will be thin patches somewhere. Bushing enamels is not difficult. The enamel can be extended with products like Penetrol to make it flow even better and give a smoother finish. Whatever way it is done, it makes for a far more manageable job of it by using a hub/spindle on which to rotate the wheel, and it helps if the wheel can then be turned to paint the other side.
I made some neat little hangers to hold the wheels while the paint dries. A large washer on a foot long length of wire is threaded through the valve stem hole and a loop in the other end of the wire is hung over a nail. The washer leaves just two tiny divots in the paint at the valve stem hole and these are easily touched up later if necessary.
Hope this helps.
Hope this helps.
- First Name: Bruce
- Last Name: Brakke
Frank, Nice looking wheel, that is the color I want.
What do you mean "using finish is hard" ?
Bruce
Bruce
was either dyslexia or Yoda - Did by using Brush, paint cured to a hard finish.
Needed several coats because of the light color. Pipe mounting shown is what I used to rotate the wheel (less the tire).
- First Name: Bruce
- Last Name: Brakke
I like the color of Frank's wheel. I would appreciate photos of other light color wheels and any color information associated with them.
- First Name: Brad
- Last Name: Kirtner
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
I painted my speedster wheels with a brush and POR-15. Light “dry brush” coats are great. Covers very well. I’ll be painting my TT stake bed with rust oleum professional thinned down out of a horrible fright $10 sprayer. Thinned with acetone and an catalyst hardener, it’s still glossy and hard as nails.
Brad
Brad
- First Name: Bruce
- Last Name: Brakke
I would appreciate more photos of light colored wheels with any specific information associated with the color.
- First Name: Bruce
- Last Name: Brakke
Waiting for replies.
- First Name: Eric
- Last Name: Macleod
- * REQUIRED* Type and Year of Model Ts owned: 13 Touring, 26 Touring (2006 Stynoski), 27 Fordor, 27 Fordor, '92 Stynoski, 'owner emeritus
My 2 cents worth was gleaned from researching wire wheel colors for my last '26 Touring. Factory wire wheels were to be supplied by the dealer on an exchange basis. For a nominal charge dealers were to offer color to be applied by the dealer with a brush, with a stripe to match. Thus, brush painted wheels are in fact the most correct option for finish painting.
1913 Touring
1926 Touring (2006 Stynoski)
1927 Fordor (2)
1927 Touring
1927 Fordor (2)
1927 Touring
OK, I know these are wood spokes but the brushing is much the same. I brush painted the yellow Speedster wheels in 1985 when Dulux enamel was available.
The pin stripes are fun to and add a lot to the look. The could distract from any imperfections too if there were any.
These pictures were just taken today so you see the paint has held up well since applied.
This Buick wheel was brush painted with Centari® Acrylic Enamel with a slow-drying agent in about 2004.
Setting the wheel hub on a table I can paint one side of the first spoke, then flip the wheel over and coat the second side of the first spoke and this side of the second. Back and forth until they are all painted. The paint flows evenly on each spoke that way. The felloe can be done between each spoke as I go or all at once after the spokes. Upright on a bar would work just as well if chosen. There are no runs and everything is coated evenly. I put two coats on. After painting a dozen sets of wheels this is how I like to do it.The pin stripes are fun to and add a lot to the look. The could distract from any imperfections too if there were any.
- First Name: LORIEN
- Last Name: HEGNER
Sprayed the wheels on our 26 with single stage enamel with hardner. Had the local paint store mix up a quart using the original straw paint code.
- First Name: Bruce
- Last Name: Brakke
Lorien, What was the "original straw paint code"?
Paint Codes
