How to remove rear hub
Unprr
Last Name: Schmidt
* REQUIRED* Type and Year of Model Ts owned: 1927 coupe, 1924 Model T pickup
Post by Unprr » Mon Jul 11, 2022 4:12 pm
I’m trying to put AC brakes on my 24 Model T. It has an adapter so Model A wheels fit. My question is how do I pull this hub.
Photo attached.
George
Elkhorn, Nebraska
Re: How to remove rear hub
Post by DanTreace » Mon Jul 11, 2022 4:59 pm
That may be an issue. Seems the new hub has a narrow groove, too small to grab with a jawed puller. Maybe you can find a big jawed puller that could wrap its arms around the plate between the drum. Or......?
Increased the size of your photo to show bit more.
I would first try a 'knock off' puller, thread it onto the stub of the axle shaft. Strike it really hard with a 2.5 - 5 lbs mallet. Should shock the new adapter and hub off the tapered axle shaft.
Wheel puller instructions - Copy.jpg (114.18 KiB) Viewed 1130 times
Post by speedytinc » Mon Jul 11, 2022 5:09 pm
Isnt it an adapted wood wheel hub? Threads still in tact? Normal wood wheel puller.
There is a type puller for v-8? that has 3 fingers that pick up studs & presses on the axle stub 9461211108033884777721
350565372576 Ebay #. as an example. I couldnt get the picture to attach
