Trivia: Exterior Door Handles?
Been Here Before
First Name: George John
Last Name: Drobnock
Post by Been Here Before » Wed Jul 13, 2022 1:54 pm
Can any one give an explanation about the styles of open and closed exterior Model T door handles from 1908 to 1927?
Re: Trivia: Exterior Door Handles?
Post by DanTreace » Wed Jul 13, 2022 3:20 pm
Generally the open cars have outside door handles until late '12. Then latch handles extended out the top of the door or later on the inside of the door.
Closed cars have door handles on the outside and inside since there are windows.
Post by Rich Eagle » Wed Jul 13, 2022 3:49 pm
Here are some 23-17? Closed car. Maybe earlier.
and:
Post by Rich Eagle » Wed Jul 13, 2022 4:06 pm
Post by Rich Eagle » Wed Jul 13, 2022 9:19 pm
Then there was the stirrup handle used on the early Coupes and Centerdoors.
http://www.mtfca.com/discus/messages/41 ... 1401417019
KBurket
First Name: K
Last Name: Burket
* REQUIRED* Type and Year of Model Ts owned: 1926 RPU
Post by KBurket » Thu Jul 14, 2022 1:39 am
Im also curious about styles used for different years.
I recently added a number of handles to my collection thanks to ModelT Matt. Some are similar to what Rich Eagle posted above.
I presume the top row are newer, maybe Model A?
I would also like to know if anyone has seen the curly handles in the second row, far right.
Post by RajoRacer » Thu Jul 14, 2022 10:24 am
Yes to top row - one with key in the center is for the rumble seat or trunk lid. I believe the fancy ones are Model A Fordor Sedan.
Post by Norman Kling » Thu Jul 14, 2022 10:56 am
In the first post one of the handles look exactly like one I had on a 31 Model A Phaeton many years ago. I had an extra handle and I used it for the parking brake handle on a 67 Dodge dart, which came with a plastic handle which would break if you pulled it on hard to hold the car on a hill. It never broke after I put the Ford handle on it.
RFH
First Name: RANDALL
Last Name: HILYER
* REQUIRED* Type and Year of Model Ts owned: 1919 COUPE
Post by RFH » Thu Jul 14, 2022 1:29 pm
These are the style handles on my 19 Coupe.
Randy
RFH
First Name: RANDALL
Last Name: HILYER
Post by RFH » Mon Jul 18, 2022 11:28 am
I was able to find out on the Coupes.
1919-1920 - Had Bail or loop style handles.
1921 - Had "T" style handles.
1922-1923 Had "L" style Handles.
I have been unable to find any reason for the changes.
I feel Ford saw the changes as improvements.
Randy
Post by Rich Eagle » Mon Jul 18, 2022 4:31 pm
I would suspect the changes were to save costs as with many other changes Ford made.
I particularly like the Bakelite covered handles with the nickeled ends.
RFH
First Name: RANDALL
Last Name: HILYER
Post by RFH » Wed Jul 20, 2022 1:28 pm
I will agree as time went onward into the Model T production.
Changes were made to make the part less expensive to produce.
This made the cost of building the car less expensive and that could be pasted onto the consumer to purchase the Model T at a lower price.
I would think the earlier handles that were cast took longer to produce and more costly.
Lots of changes were made during production.
It all makes sense Henry was very sharpe !
