What is the correct fastener to attach the Cowl Lacing to wood firewall on a1922 Touring.
Rick.
Cowl Lacing attachment 1922 Touring
Topic author - Posts: 60
- First Name: Rick
- Last Name: Shaw
- * REQUIRED* Type and Year of Model Ts owned: 1922 Touring. 1924 Coupe
Re: Cowl Lacing attachment 1922 Touring
I don't know what year this is but suspect they are all the same.
Do you need the location measurements?
P.S. they mention "3/4 inch #15 cement coated wire nails from 1919 to 1923" in this forum thread. That must be what these were.
http://www.mtfca.com/discus/messages/118802/156801.html
I measure the nail at .192 Ø for the head, .074 Ø shank and .731 long. It is steel. These also hold the metal strip to the wood.Do you need the location measurements?
- First Name: Ben
- Last Name: Austin
I used 3/4" stainless brads/wire nails worked fine.
I went to Ace hardware and bought some tacks that closely resembled the few that were still in the remains of the firewall I had on my 21 Touring.
- First Name: Rick
- Last Name: Shaw
Thanks for all the great info
I'll see what I can find
