What's this?
Topic author - Posts: 415
- Last Name: Foye
- * REQUIRED* Type and Year of Model Ts owned: 27 Fordor, 15 speedster (2), 23 touring, 26 fordor, 25 TT
What's this?
Found this starter in the pile - does anyone know anything about the bendix?
Gen III Antique Auto - we do Model T Ford Restorations
You can have everything in life you want, if you will just help other people get what they want -Zig Z.
https://www.youtube.com/channel/UCeROBg ... pB-KImprjw
Re: What's this?
Not specifically, but I have another, different looking non bendix bendix.
Its a starter drive that gets around the bendix patents.
Real neat display piece.
- Last Name: Pharis
Re: What's this?
For some reason I wanna say that is a ‘28 AR bendix drive. The AR had the same diameter shaft as the T, but used a cam operated drive. Not sure if they would have been interchangeable, but suspect someone put it on the T starter but never ran it
- Last Name: Pharis
- Last Name: Foye
Re: What's this?
The front bushing was modified too - what you see sticking out does not turn. Only the gear+ does.
