My idiot email refuses to send a message to Russ, so I'll ask here.
I have my speedometer installed, but I haven't connected the cable to the swivel because of a malfunction. The swivel turns CCW, which I believe is correct. But it turns only when the wheel rotates backwards!
Have I installed the gears and swivel incorrectly?
Do I have the wrong swivel?
Stewart Model 100 problem
Topic author - Posts: 7344
Re: Stewart Model 100 problem
Since you have a non original '15, is that why you wish to use a 100?
- First Name: Russ
- Last Name: Furstnow
- * REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo,1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet, 1917 Coupelet
Something is wrong with your internal gears. Turning your wheel in either direction should make the swivel output shaft turn. Give me a call since your email isn't working. Russ Furstnow
I wish to use a 100 because I got it at a reasonable price, has an odometer, and is an aftermarket accessory that was sold for 1915-1918 Fords. I don't see that the impurity of my vehicle should preclude the use of a period accessory.
Great. I found two phone numbers and both got a "cannot be completed as dialed" message. Maybe you can call me.
Three won sicks, 7 7 too, 7 fore too won.
