Interesting little article.
https://silodrome.com/1914-ford-model-t ... D=ref_fark
							A 1914 Ford Model T Motor Caravan – The Oldest Surviving Motorhome In The World
				Petrah Phyre
Topic author - Posts: 162
 - First Name: Sean
 - Last Name: Pownall
 - * REQUIRED* Type and Year of Model Ts owned: 1926 Speedster
Re: A 1914 Ford Model T Motor Caravan – The Oldest Surviving Motorhome In The World
That is really cool!  But I bet it was lucky to make it to 15 mph what with all that weight!
				Kerry
 - Last Name: van Ekeren
It has forma-truck gearing fitted so that's about all it would anyway.
Good photos of the custom build too.  Note the photos of the engine compartment, the plug wires are a bit aged now
And only high head bolts were found during restoration, as they have spacers to be used on that low cylinder head!
The best way is always the simplest. The attics of the world are cluttered up with complicated failures.     Henry Ford
 - First Name: Austin
 - Last Name: Farmer
You will not need a slow moving vehicle sign for that, you will need a "Slow Moving House" sign.
That is a neat camper!
Kaiser
 - First Name: Leo
 - Last Name: van Stirum
Here's the next step up from that camper
							- Attachments
- images.jpeg (13.41 KiB) Viewed 2198 times
Leo van Stirum, Netherlands
				Southfork Creek
 - Last Name: Wightman
LOL, and when it got towed, it became the worlds' first 5th wheel.
