Brake band material
Chris Haynes
Topic author - Posts: 400
- First Name: Chris
- Last Name: Haynes
- * REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
Brake band material
I know that bands are available in a variety of materials. My question is which one gives the most braking power?
Re: Brake band material
I believe that any of the lining materials are capable of sliding the rear wheels if everything is in good adjustment. Kevlar is probably the longest lasting.
Moxie26
- Last Name: Jablonski
Let's clarify this request.. referring to emergency brake bands, or transmission brake bands?
- Last Name: Patrick
Everyone has his favorite, me included. In my 52 years of owning my 1926 Coupe, I have used Scandinavian woven bands, Kevlar woven bullet proof bands and Guinn’s wood bands and I much prefer the wood bands. Scandinavian woven bands (which is what Model T’s originally used in the day), which are not very durable, can be shredded with one hard stop. Kevlar, which is as hard as the steel drums, is a little too durable and can crack or score your drums after a hard stop. Wood bands are durable but not so durable as to harm your drums and work very smoothly. Some may disagree, but it is what I have learned over the years. Jim Patrick
As Jim points out everyone has their favorites & it would appear that each option provides about the same breaking power. So perhaps choices can be made on some of the pros & cons.
Woven cotton fabric shreds its lint;
Kevlar can cause drum failure.
Wood, chattering in reverse.
are there more pros & cons? I'd go with the one that would be the least problematic, risk of/causing failure and require the least adjustment once applied
Chris Haynes
- First Name: Chris
- Last Name: Haynes
My 1921 parking brake has no lining. No bands are used on the parking brake.
Moxie26
Chris simply if you stated what year model T you were working on, replies would have been more specific. Lined
emergency brake shoes were installed for the 26-27 model years, prior to that were cast metal shoes against the brake drum. As far as transmission band linings there are several materials available cotton, wood, Kevlar, and Brand x.. take your pic. My preference are the wood band liners.... Depending on availability at the vendor of your choice they may or may not have your preference.
Do you need to update your profile to avoid confusion in the future?Chris Haynes wrote: ↑Mon Sep 05, 2022 4:36 pmMy 1920 parking brake has no lining. No bands are used on the parking brake.
- Attachments
- rrrrr.png (22.67 KiB) Viewed 3577 times
Whats available (see langs) is a 1 piece cast iron shoe with a grey modern brake lining. Better than nothing. They do work, but be warned they take a lot of "fitting" which includes narrowing. They are not good enough to rely on(IMO) as an external brake band setup or R/M brakes.Chris Haynes wrote: ↑Mon Sep 05, 2022 4:36 pmMy 1920 parking brake has no lining. No bands are used on the parking brake.
Occasionally period replacement shoes show up @ swap meets with a woven lining.
Chris Haynes
- First Name: Chris
- Last Name: Haynes
As you can see profile says I have a 1921 Runabout.TRDxB2 wrote: ↑Mon Sep 05, 2022 5:32 pmDo you need to update your profile to avoid confusion in the future?Chris Haynes wrote: ↑Mon Sep 05, 2022 4:36 pmMy 1920 parking brake has no lining. No bands are used on the parking brake.
Chris Haynes
- First Name: Chris
- Last Name: Haynes
I asked for brake, not emergency brake. Emergency brakes don't have bands do they?Moxie26 wrote: ↑Mon Sep 05, 2022 4:59 pmChris simply if you stated what year model T you were working on, replies would have been more specific. Lined
1926-‘27 T’ emergency brakes have brake linings but not made out of multiple materials. The fact that the question was asking which band lining material was the best made it obvious the question was referring to transmission band linings. Just sayin’.
Jim Patrick
Chris Haynes
- First Name: Chris
- Last Name: Haynes
Thank you Jim. Finally a voice of intelligence.jiminbartow wrote: ↑Tue Sep 06, 2022 10:36 pm1926-‘27 T’ emergency brakes have brake linings but not made out of multiple materials. The fact that the question was asking which band lining material was the best made it obvious the question was referring to transmission band linings. Just sayin’.Jim Patrick
