Bending Bendix washers
tom_strickling
Last Name: Strickling
* REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
Post by tom_strickling » Fri Sep 30, 2022 6:53 pm
Concerning bendix spring bolt washers. Does it matter where the tab that bends down rests? Should it touch the outer surface of the bendix spring or should it be down in "the gap" and the end of the spring
Re: Bending Bendix washers
Post by speedytinc » Fri Sep 30, 2022 6:57 pm
The lower tab locks into the spring eye gap. It does matter.
To be clear, its the pre bent tab that goes in the gap. The tab you bend rests against the lock bolt face.
tom_strickling
Post by tom_strickling » Fri Sep 30, 2022 7:02 pm
Thanks. Is it in the gap enough as is or do you have to bend it into the gap a little more?
Post by Jerry VanOoteghem » Fri Sep 30, 2022 7:26 pm
It just needs to be in the gap enough so that the washer can't rotate and allow the bolt to back out.
tom_strickling
Post by tom_strickling » Fri Sep 30, 2022 7:50 pm
Got it Thanks agian.
