1925 Runabouts
Topic author - Posts: 3781
1925 Runabouts
Does anyone have any data on when Ford introduced the new style metal tool box, and back rest cushion supports? I'm thinking April, but really don't know for sure. I once owned a March 1925, and it didn't have any of that.
- Last Name: Elenbaas
- * REQUIRED* Type and Year of Model Ts owned: 1914 Runabout, 1916 Delivery, 1925 Roadster PU, 1926 Speedster
Re: 1925 Runabouts
Larry,
My late April roadster pickup has the metal toolbox and the improved single choke, carb adjustment.
Re: 1925 Runabouts
Thanks Jim. Next time I go to the archives, I should check on this.
- Last Name: Warren
Re: 1925 Runabouts
Can you guys post any photos? My tool box is wood. Thanks
Re: 1925 Runabouts
John: Good to see you at Bakersfield again, and Dan too. Here are some pictures of the back rest cushion wood, and special brackets that are used to partially hold the metal tool box used in the late '25 roadsters. As far as I know Howells sells the metal tool box insert.
- First Name: Darryl
- Last Name: Bobzin
- * REQUIRED* Type and Year of Model Ts owned: 2, '25 T Runabouts, '14 Touring
Re: 1925 Runabouts
I have a late '25 Roadster (July '25), but sadly when it was "restored" some time in the '70's the tool tray and any trace of the brackets were lost. I am not sure it would be worth the trouble to try to fit them at this point. Maybe if I ever do a total restoration.
