What is this?
Randy Mock
First Name: Randy
Last Name: Mock
What is this?
Post by Randy Mock » Sat Oct 22, 2022 7:55 pm
I made a purchase today.
Some are T some not so much.
Any help is appreciated.
Probably for sale soon.
Re: What is this?
Post by RajoRacer » Sat Oct 22, 2022 8:33 pm
That's a Babbitt setting hammer underneath the gray gizmo - the white tubes appear to have Babbitt cutting tooling !
Randy Mock
First Name: Randy
Last Name: Mock
Re: What is this?
Post by Randy Mock » Sat Oct 22, 2022 8:54 pm
I will get everything out for a better picture tomorrow.
Last Name: Tannehill
Re: What is this?
Post by JTT3 » Sat Oct 22, 2022 9:51 pm
Randy Mock
First Name: Randy
Last Name: Mock
Re: What is this?
Post by Randy Mock » Sat Oct 22, 2022 10:33 pm
I’m hoping the gray gizmo is something rare.
It’s likely the profit off this job.
Chris Paulsen
First Name: Chris
Last Name: Paulsen
* REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1914 Pickup
Re: What is this?
Post by Chris Paulsen » Sun Oct 23, 2022 1:16 am
The gray “gizmo” is the feed for line boring equipment. Not necessarily rare or valuable but a good item if it’s not worn out. I’d be interested if it’s available and in good condition.
Re: What is this?
Post by Norman Kling » Sun Oct 23, 2022 11:13 am
Those axles look like you might have a "wide track" model T. Quite rare.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: What is this?
Post by Dan McEachern » Sun Oct 23, 2022 1:14 pm
The grey gismo is the Feed mechanism for an Aamco Line boring bar. Given the other items in that box, you might have the other parts that go to it as well. Post more pics of your treasures.
The ribbed tool laying under the gear rack of the feed box is a KRW main bearing babbitt peening tool.
Randy Mock
First Name: Randy
Last Name: Mock
Re: What is this?
Post by Randy Mock » Sun Oct 23, 2022 6:46 pm
More unknown
Randy Mock
First Name: Randy
Last Name: Mock
Re: What is this?
Post by Randy Mock » Sun Oct 23, 2022 6:47 pm
I assume all babbitt related
Re: What is this?
Post by RajoRacer » Sun Oct 23, 2022 9:58 pm
W.A.G. - appear to be Model A related. There's a pouring jig, pouring blocks and a thrust cutter.
Dave Sullivan
First Name: David
Last Name: Sullivan
* REQUIRED* Type and Year of Model Ts owned: 1923
Re: What is this?
Post by Dave Sullivan » Sun Oct 23, 2022 10:47 pm
I'd say the (Grey gizmo) is part of a line bore outfit.. Dave in Bellingham, WA
dobro1956
First Name: Donnie
Last Name: Brown
Re: What is this?
Post by dobro1956 » Mon Oct 24, 2022 6:00 pm
#2 is a rear main thrust facer. The size of shaft will determine if it is A or T. #5 are main bearing pouring blocks. A set of them is usually 6 blocks but 2 long ones and 1short one will do.
Randy Mock
First Name: Randy
Last Name: Mock
Re: What is this?
Post by Randy Mock » Tue Oct 25, 2022 2:02 pm
Thanks for the info
